Waiting for missing types to be registered: - onvif-config
Hello, I currently have a problem with my node-red application.
Flows stopped due to missing node types.
  • onvif-config
Close
27 Feb 14:29:11 - [info] Waiting for missing types to be registered:
27 Feb 14:29:11 - [info] - onvif-config
How can I solve this?
what did you do prior to this happening? My guess - you imported a flow?
Question is - do you WANT onvif or not (the solution changes upon your requirement).
want onvif
  • install onvif node (whatever that is)
dont want onvif / just want node-red working again
  • look in the config nodes on the side bar - remove anything resembling onvif & deploy.
This worked.
Thanks.
