Hi guys,
when i am moving my flows from one computer to the next I get first the below error in the terminal:
After which I checked the versions of both node-red versions and the UI-Table node... I noticed an error in the pallet manager.
What could cause this issue?
I already removed the flow, reinstalled the ui-table node and updated and upgraded node-red
this is the section in the node that seems to throw the error
1 - what version of Node-red and node.js is the original computer running? (you can get this from the startup log)
2 - what version of node-red-node-ui-table is the original computer running?
3 - what type of device is the original computer?
4 - what type of device is the new computer?
5 - what version of Node-red and node.js is the new computer running?
If the node-red-node-ui-table running on the old computer is not the current version (v 0.3.12) you could try installing the prior version to see if some change is causing the issue.
Indeed there was an issue with the version of the ui table node.
Updated the node after the error occured, it did not solve it. I had to re install nodered the get this out.
