Warnings after update
I am seeing the following warnings in the debug after updating to 14.5.0.
What should I do?
9/14/2023, 8:24:46 AMnode: sum min
status : msg.payload : number
1
9/14/2023, 8:24:47 AM
msg : string[270]
"Deprecated API warning: Calls to RED.util.evaluateJSONataExpression must include a callback. This will not be optional in Node-RED 4.0. Please identify the node from the following stack and check for an update on npm. If none is available, please notify the node author."
msg : string[754]
"Error: ↵ at Object.evaluateJSONataExpression (/opt/node_modules/@node-red/util/lib/util.js:775:18)↵ at JSONataService.evaluate (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/JSONataService.js:58:39)↵ at ComparatorService.getComparatorResult (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/ComparatorService.js:108:94)↵ at PollState.getComparatorResult (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:128:39)↵ at PollState.onTimer (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/poll-state/controller.js:82:30)↵ at listOnTimeout (node:internal/timers:569:17)↵ at processTimers (node:internal/timers:512:7)"
9/14/2023, 8:25:25 AM
The firrst warning tells you what to do.
contact the author of HA node and warn them that as of Node-red 4.0 the callback function will be required to be asynchronous
more info here
Scroll down to Deprecating synchronous access to JSONata
I have no idea how to "identify the node from the following stack." Where is the stack? What stack? lol
please let me know if there is documentation so I can read how to do this. Or it may be faster letting me know IDK. thanks.
Tells you module in second warning
Find contrib node in flow library, there will be a link to the github page. There you can raise an issue.
well I will try and find the node. Thanks
ok found what I think poll-state
You don't have to do anything but let the author know, so they can fix it before Node-red 4 is released.
