Warnings from node-red-dev validate
Hi there,
I'm developing a project that run under Node-RED 5. When running node-red-dev validate for my project, I'm getting the following output:
$ npx node-red-dev validate
    ---Validating Package---
   @platynum/certification-authority@2.1.0
✅ Package is AGPL-3.0-or-later licensed
✅ Repository/Bugs Link Supplied
✅ Package uses a Scoped Name
✅ No similar named packages found
✅ Node-RED Keyword Found
 ›   Warning: P06 NOT Compatible with Node-RED v1.3.7
 ›   Warning: P06 Not Compatible with any current Node-RED versions
 ›   Warning: P06 NOT Compatible with Node-RED v2.2.3
 ›   Warning: P06 NOT Compatible with Node-RED v3.1.15
I'm having two questions here:
  • Why does it output Package uses a Scoped Name twice?
  • Why does it warn about Not Compatible with any current Node-RED versions? And how can I change this?
Hi @augjoh
node-red-dev hasn't had much attention for some time. I suspect it just hasn't been updated to be aware of NR 5.
If I get a a chance, I'll give it a look.
Nick
