Weather icons used in Dashboard 2.0
Hello i'm a node-red newbe. This is my first post in thes forum ...
I found a discription to use weather-icons in the 'old' dashboard ... Flow showing Node-red ui OpenweatherMap ...
I try to transform this to 'dashboard 2.0'.
It seems to me thats not possebile to put 'msg.payload' to a 'class' entry of a dashboard 2.0 'template' ...
My code in the Template node looks like this:
<template>
    <div class="condition_icon">
        <i class="fa-4x wi {{msg.payload}}"></i>
    </div>
</template>
<style>
    @import "/weather-icons/mycss/weather-icons.min.css";
    .condition_icon {
        display: flex;
        height: 100%;
        justify-content: center;
        align-items: center;
</style>
If i look in the HTML inside the Browser the result looks like:
<div class="condition_icon" state="[object Object]" style="grid-row-end: span 2;">
</div>
But i need ther the 'payload'.
Hi @David83 - welcome to the forums, and thanks for the question
Under the covers, new Dashboard uses VueJS for it's ui-template node, so we follow that syntax.
In this case, you can use the : notation to define any attribute as dynamic.
With a dynamic class, if your msg.payload will explicitely be your class name, you can use:
<i :class="'fa-4x wi ' + msg.payload">...</>
Hi @David83,
I found some example cards that show weather information and I modified it to display data from OWM source. You may find it useful: https://youtu.be/EESuQfSBYzo
Sample flow is in the video description.
@joepavitt thanks that works fine :smiley:
