Hi, know nothing about Node red , but would like to get so you could control this relay via NodRed, send with some instructions ...
On this forum they get it to work
Loxforum
Loxforum
Did a quick flow for you.. this should open and close relay 1
Make sure you put the IP address of your board in the TCP node
[{"id":"8319a970.877298","type":"tcp out","z":"eb3d7fa.90ab38","host":"192.168.1.100","port":"1234","beserver":"client","base64":false,"end":true,"name":"","x":450,"y":700,"wires":[]},{"id":"ea489ab5.50ce68","type":"inject","z":"eb3d7fa.90ab38","name":"Open Relay","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"L1\\r\\n","payloadType":"str","x":170,"y":700,"wires":[["8319a970.877298"]]},{"id":"2fb813e6.d4939c","type":"inject","z":"eb3d7fa.90ab38","name":"Close Relay","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"D1\\r\\n","payloadType":"str","x":170,"y":740,"wires":[["8319a970.877298"]]}]
hope that helps!
Thanks, will test when I get home from work
//Baxe
One question only, the idea is that I will control this from my Home seer installation, have the connection ready in Node-Red to Home seer so I know it works, how do I do in Node-Red so that it will be right.
// Baxe
You need to put a debug on virtual device to see what comes out of it.
Then you will need to put a change node in which will change that from its output to L1\n\r for ON and D1\n\r for OFF then it should all work as you wanted it
I get out this when I puch buttons from Homeseer on/off
2021-02-11 06:09:04node: ef12336f.a8582msg.payload : Object
{ ref: 4336, name: "Belysning Biorum", location: "Unknown", location2: "Virtual Device", value: 100 … }
2021-02-11 06:09:08node: ef12336f.a8582msg.payload : Object
{ ref: 4336, name: "Belysning Biorum", location: "Unknown", location2: "Virtual Device", value: 0 … }
Thanks testing when coming home
sorry now i can see the debug properly..
I could be wrong (somebody correct me if i am)
do a function node and put this inside
msg.payload = msg.payload.value
Thank you, can you show in more detail where to enter?
//Baxe
before the change node
Why are you putting the code in the function nodes ‘setup’ section and not in the ‘function’ section?
Good question, I know nothing about Node-red, but tested what you said and now it works
Just a question web relay disconnects sometimes, is there any alternative so you can get it to connect before the code is sent?
Tanks
//Baxe
Sorry, I can't help you there. Maybe one of the other posters can.
the TCP port is timing out I would guess.
Change the properties of the TCP node to say "close every connection after message is sent"
