Webcam / IFrame problem with LAN / WAN enviroment
Hiho my friends. I ve a problem with iframes of my webcams when changing the network enviroment.
I forwarded my ports of the node red user interface to make it accessable from everywhere in the www.
I ve some webcams in my menu having their own webinterface. I used a iframe node and linked to these webinterface. (shot1) Everything works fine as long as I am using my ui from my lan. If I call my ui from www the iframes will not work because they link to an internal ip adress witch is not access able from there.... I could change the ip to an external one but that would force the interface allways to route all data through the www. this would cause a delay, traffic and would bound my node red ui to a working www (at least the webcams). Any solutions for making the iframe ui link dynamic or something else that could help ?
thanx !
This is not recommended, unless you know how to secure it properly.
You might want to read this
thanx, but of course I secured node red by using adminAuth, ports > 1024. (like the article tells), I ve backups.... https will follow.
.... but the problem still remains. can anybody help me on that ?
Rereading your topic: your problem will remain unless you open all your cams up to the internet too.
Possible solution: use vpn.
Solution goes like this:
  • webcam 1 interface is reachable at 192.168.0.55:8055 in local network and myhome.ddns.net:8055 in www
  • Create an new group assigned with a template node and use the browser debugging tools to search for a unique indentfier. in my case "Webcam_Test_1_Test_Aufbau_cards md-card"
    (shot)
  • put my code into the template node. the code will basicly
<script>
(function() {
    const external = 'myhome.ddns.net';
    let isLocal = window.location.hostname !== external;
    let cam1 = (isLocal ? '192.168.0.55' : external) + ':8055';
    let cam2 = (isLocal ? '192.168.0.56' : external) + ':8056';
    let iframe = document.createElement('iframe');
    iframe.src = 'http://' + cam1;
    iframe.style.height = '400px';
    //iframe.style.border = '2px solid red';
    document.querySelector('#Webcam_Test_1_Test_Aufbau_cards md-card').appendChild(iframe);
</script>
The script will replace the iFrame url depending from the variable "window.location.hostname" to identify if the call was made from myhome.ddns.net or if not local....
Some words to VPN solution: Installing a VPN on my system will cost resources which I need for other stuff. the 1GB RAM of my raspi is on the limit and switching to raspi 4 will be an efford that I ve no time for atm.
As always sorry for my bad english :slight_smile:
I hope your time is worth more than the security of your home.
