This seems to have just happened recently.
(It has to be recent as I have only made these flows recently.)
Attached are two pictures.
NR 0.19.4
Dashboard (recently updated) 2.14.0
Normally the screen is good, but now and then part of the GUI goes away.
I don't think I need to say which part.
If/when it happens, if I refresh the page, it is ok.
Code for the whole page below.
[{"id":"a6e58cf3.b2eaa8","type":"tab","label":"Linear gauge","disabled":false,"info":""},{"id":"1f7f2889.e4bc7f","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"5b3f71fc.b21d3","order":0,"width":0,"height":0,"name":"Name","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"","x":690,"y":300,"wires":[[]]},{"id":"937cd0f9.cec28","type":"inject","z":"a6e58cf3.b2eaa8","name":"Max","topic":"msg.highlimit","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":300,"wires":[["a6240d8c.7c85b8"]]},{"id":"82c68e3b.983528","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":430,"wires":[["4e848a43.b40df4"]]},{"id":"eed28967.81cfd8","type":"inject","z":"a6e58cf3.b2eaa8","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":108,"y":551,"wires":[["82c68e3b.983528","e140b01d.0f1c8","f0adef21.32955","ed25bb4f.ec4d","5e3d3567.86cb34","330ce5fe.b55f22"]]},{"id":"4e848a43.b40df4","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":430,"wires":[["4dcc08a9.15951"]]},{"id":"2abae45f.96711c","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":470,"wires":[["17a653f2.04497c"]]},{"id":"e140b01d.0f1c8","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":470,"wires":[["2abae45f.96711c"]]},{"id":"c4d76081.8db048","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":510,"wires":[["98546aa6.5e61d8"]]},{"id":"f0adef21.32955","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":510,"wires":[["c4d76081.8db048"]]},{"id":"ed25bb4f.ec4d","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":550,"wires":[["6b81d638.8b1c38"]]},{"id":"6b81d638.8b1c38","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":550,"wires":[["b8a06010.58fb7"]]},{"id":"a6c57923.d0484","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":590,"wires":[["fcc9e9f0.18b05"]]},{"id":"5e3d3567.86cb34","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":590,"wires":[["a6c57923.d0484"]]},{"id":"25a1d47f.579ecc","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":630,"wires":[["4cdfb8a0.77691"]]},{"id":"330ce5fe.b55f22","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":630,"wires":[["25a1d47f.579ecc"]]},{"id":"4dcc08a9.15951","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":0,"width":"2","height":"5","name":"Tank #2","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":430,"wires":[[]]},{"id":"17a653f2.04497c","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":1,"width":"2","height":"5","name":"Tank #3","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":470,"wires":[[]]},{"id":"98546aa6.5e61d8","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":2,"width":"2","height":"5","name":"Tank #4","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":510,"wires":[[]]},{"id":"b8a06010.58fb7","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":3,"width":"2","height":"5","name":"Tank #5","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":550,"wires":[[]]},{"id":"fcc9e9f0.18b05","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":4,"width":"2","height":"5","name":"Tank #6","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":590,"wires":[[]]},{"id":"4cdfb8a0.77691","type":"ui_lineargauge","z":"a6e58cf3.b2eaa8","group":"839cb537.68ab18","order":5,"width":"2","height":"5","name":"Tank #7","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":700,"y":630,"wires":[[]]},{"id":"d56ba53e.074438","type":"change","z":"a6e58cf3.b2eaa8","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":300,"wires":[["1f7f2889.e4bc7f"]]},{"id":"6076c897.13684","type":"ui_level","z":"a6e58cf3.b2eaa8","group":"6214df15.ae6b9","order":0,"width":"6","height":"1","name":"VU test","label":"Label","colorHi":"#e60000","colorWarn":"#ff9900","colorNormal":"#00b33c","colorOff":"#595959","min":0,"max":"50","segWarn":"30","segHigh":"60","unit":"x","layout":"sh","channelA":"","channelB":"","decimals":0,"animations":"reactive","x":510,"y":730,"wires":[]},{"id":"8df9a257.c030c","type":"inject","z":"a6e58cf3.b2eaa8","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":130,"y":730,"wires":[["d7dfc01d.90e3d8"]]},{"id":"d7dfc01d.90e3d8","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":730,"wires":[["6076c897.13684","80203c39.c8c388"]]},{"id":"80203c39.c8c388","type":"ui_text","z":"a6e58cf3.b2eaa8","group":"6214df15.ae6b9","order":0,"width":0,"height":0,"name":"","label":"Value","format":"{{msg.payload}}","layout":"row-center","x":500,"y":780,"wires":[]},{"id":"a6240d8c.7c85b8","type":"random","z":"a6e58cf3.b2eaa8","name":"","low":"20","high":"45","inte":"true","property":"payload","x":330,"y":300,"wires":[["d56ba53e.074438"]]},{"id":"5b3f71fc.b21d3","type":"ui_group","z":"","name":"Home","tab":"bab81a9e.75a6","order":2,"disp":true,"width":"3","collapse":false},{"id":"839cb537.68ab18","type":"ui_group","z":"","name":"Linear Gauges","tab":"bab81a9e.75a6","order":1,"disp":true,"width":"12","collapse":false},{"id":"6214df15.ae6b9","type":"ui_group","z":"","name":"VU","tab":"bab81a9e.75a6","order":3,"disp":true,"width":"6","collapse":false},{"id":"bab81a9e.75a6","type":"ui_tab","z":"","name":"Linear gauge","icon":"dashboard","order":35}]
