Weird: use of a button causes "Connection lost"
Is that line on the front in the file, or did you mess up the copy/paste. If you click the pencil icon next to the post you can correct it.
Did you uninstall the file function node before posting that, as suggested by @zenofmud? What does the startup log look like now?
As previously suggested it would probably be a good idea to update node red before giving up.
Latest dashboard requires at least nodejs 14. You are using v12. You will need to upgrade
Are you sure that is correct? When this question was first posted I checked Releases · node-red/node-red-dashboard · GitHub the last reference to nodejs is for version 3.0.4 which says "Set minimum requirement to be Node12 (in line with core)".
Also, package.json has
    "engines": {
        "node": ">=12"
true... but it may be that one of the libraries has updated enough to break it. I guess they could try pinning back to a previous version of dashboard... but I think upgrading would be better longer term.
Certainly.
The original problem occurred on NR v2.1.4. zSince then the user installed NR v 3.02 on another Pi and the problems gone away.
