What URL to use for http request node?
Hey All.
First time working with JSON and I'm setting up a http request node but I don't know what URL to use. I'm working on a local network.
The JSON I'm interested in is coming from a form on the dashboard and I'm trying to show the data on the same dashboard. How do I know what URL to use for the IP address?
this is the address of my dashboard.
http://192.168.1.***:1880/ui/#!/0?socketid=5Y9uUwVVuL7ozybRAAAB
the variable I want is called deskBrightness I think it should look something like this but it doesn't work...
http://192.168.1.***:1880/ui/#!/0?socketid=5Y9uUwVVuL7ozybRAAAB{{{deskBrightness}}}
Please check out my flow if you have a minute.
Rich
        "id": "a1daf67020415503",
        "type": "inject",
        "z": "cb58b0f2ac83d096",
        "props": [
                "p": "payload"
        "repeat": "3",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "8",
        "payloadType": "num",
        "x": 90,
        "y": 600,
                "1adcbd7787bbc99e"
        "id": "1adcbd7787bbc99e",
        "type": "ui_form",
        "label": "deskBrightness",
        "group": "3d153cb1a380b89c",
        "order": 5,
        "width": 0,
        "height": 0,
        "options": [
                "value": "deskBrightness",
                "type": "number",
                "required": true,
                "rows": null
        "formValue": {
            "deskBrightness": ""
        "payload": "",
        "submit": "submit",
        "cancel": "",
        "topic": "payload",
        "topicType": "msg",
        "splitLayout": "",
        "className": "",
        "x": 260,
        "y": 600,
                "faa8886a317a5867"
        "id": "faa8886a317a5867",
        "type": "http request",
        "name": "HTTP Request (POST)",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "socketid=5Y9uUwVVuL7ozybRAAAB{{{deskBrightness}}}",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 510,
        "y": 600,
                "24bd94a6ca28cffd",
                "3ab83c4d2a526220"
        "id": "24bd94a6ca28cffd",
        "type": "ui_text",
        "order": 6,
        "width": 0,
        "height": 0,
        "label": "Brightness Level",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "className": "",
        "x": 770,
        "y": 620,
        "id": "3ab83c4d2a526220",
        "type": "debug",
        "name": "debug 165",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "deskBrightness",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 770,
        "y": 560,
        "id": "3d153cb1a380b89c",
        "type": "ui_group",
        "name": "LED Switch",
        "tab": "c548a45fe690539c",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "c548a45fe690539c",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": true
Why do you need to use the http request node for the dashboard ?
Can you explain what you are trying to achieve ?
I'm also sending the data to an Arduino but it doesn't understand JSON. I'm trying to view the Int inside the JSON file.
How can I do this?
I've done some more reading but I'm still stuck. Maybe something like this?
        "type": "ui_form",
        "order": 5,
        "width": 0,
        "height": 0,
        "options": [
                "type": "number",
                "required": true,
                "rows": null
        "formValue": {
        "payload": "",
        "submit": "submit",
        "cancel": "",
        "topic": "payload.deskBrightness",
        "topicType": "msg",
        "splitLayout": "",
        "className": "",
        "x": 260,
        "y": 600,
                "0b7f7b973b9314b9"
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "3",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "8",
        "x": 90,
        "y": 600,
                "1adcbd7787bbc99e"
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "statusVal": "",
        "x": 850,
        "y": 600,
        "id": "5c17735b35843a58",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.deskBrightness",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 640,
        "y": 600,
                "3ab83c4d2a526220"
        "id": "0b7f7b973b9314b9",
        "type": "json",
        "property": "payload",
        "action": "obj",
        "pretty": true,
        "x": 430,
        "y": 600,
                "5c17735b35843a58"
        "type": "ui_group",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "type": "ui_tab",
        "name": "Home",
        "order": 1,
        "disabled": false,
        "hidden": true
FYI: there is an Arduino Json library
