HELLO
What we want is to sound an alarm and display text when the temperature rises. Please refer to the data.
flows (3).json (27.8 KB)
HELLO
No one in their right mind, is going to suddenly import your flow, and tell you how to set it up, to avoid giving you an answer you CLEARLY don't want.
Maybe explain your setup in detail, what alarm you are referring to, what temperature probes you use, an example of a payload you receive and what video you are referring to?
Then maybe someone will take time out of their day to kindly help you out.
Please reduce the flow to an example that focuses on your issue.
One thing I've noticed though: It looks like you're trying to compare numbers against strings:
I'm pretty sure this cannot give you the expected result.
Javascript is very forgiving, but it shouldn't harm to change the type field to number (via the dropdown depicted az in the screen shot).
Please use the forums system to post flows, as it makes coping it a simple click and not having to download a file open it , copy text and then paste into editor.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
Use the </> icon to create the triple backticks.
You can edit and correct your post by clicking the pencil
icon.
Does it fit like this?
"id": "d1ce905ecd7ab3a0",
"type": "tab",
"label": "Flow 4",
"disabled": false,
"info": "",
"env": []
"id": "0b9258851d325b67",
"type": "group",
"z": "d1ce905ecd7ab3a0",
"style": {
"stroke": "#999999",
"stroke-opacity": "1",
"fill": "none",
"fill-opacity": "1",
"label": true,
"label-position": "nw",
"color": "#a4a4a4"
"nodes": [
"28a1b0ed1013a7c7",
"feee90c2fd86775a",
"f63c8cdd374f583a",
"32b7525b89b009da",
"d57e41cc9271e044",
"e049cc591e54b32c",
"06ce1f0bdd299082",
"5ea39b32df41862b",
"14458a4b703c0f6e",
"ee1f5adc2a6ae7ee",
"81dee7335d1f8620",
"fac60d0bfab12664",
"1e7d1ecfada49883",
"61375eef5be2bacf",
"1fd93f5e0ee0d02e",
"a4cf717d039d6122",
"57efb1527c93fcc9",
"0f09d3f3065d9b71",
"55a45dc0a51160b3",
"ced39c5519c7c9a1",
"9009c9d5dd981aa0",
"4474bfef90c4cf49",
"849488f8e9219852",
"6216cbdf2da3565a",
"8faaf2e38182fb47",
"15905cf37a1e0c89",
"d179a286befbcd9f",
"224d4dd1adddc636",
"b290f3aa454e0b43",
"66dcd9d067ca37ab",
"afc4a8483085dfe1"
"x": 274,
"y": 299,
"w": 1072,
"h": 582
"id": "28a1b0ed1013a7c7",
"type": "play audio",
"g": "0b9258851d325b67",
"voice": "0",
"x": 1190,
"y": 460,
"id": "feee90c2fd86775a",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" 텐타 1호기 열풍모터 우넘버1 온도 오류\"",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 460,
"28a1b0ed1013a7c7"
"id": "f63c8cdd374f583a",
"type": "debug",
"name": "debug 141",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 720,
"y": 340,
"id": "32b7525b89b009da",
"type": "split",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"arraySpltType": "len",
"stream": false,
"addname": "topic",
"x": 670,
"y": 840,
"d57e41cc9271e044"
"id": "d57e41cc9271e044",
"type": "switch",
"property": "topic",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "temperature",
"vt": "str"
"t": "eq",
"v": "x_rms_ACC_G",
"vt": "str"
"t": "eq",
"v": "x_velocity_mm_sec",
"vt": "str"
"t": "eq",
"v": "y_rms_ACC_G",
"vt": "str"
"t": "eq",
"v": "y_velocity_mm_sec",
"vt": "str"
"t": "eq",
"v": "z_rms_ACC_G",
"vt": "str"
"t": "eq",
"v": "z_velocity_mm_sec",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 7,
"x": 930,
"y": 800,
"e049cc591e54b32c"
"06ce1f0bdd299082"
"06ce1f0bdd299082"
"06ce1f0bdd299082"
"id": "e049cc591e54b32c",
"type": "ui_chart",
"group": "e7c58517fc955493",
"order": 1,
"width": 9,
"height": 6,
"label": "Temp",
"chartType": "line",
"legend": "false",
"xformat": "HH:mm",
"interpolate": "linear",
"nodata": "",
"dot": false,
"ymin": "0",
"ymax": "40",
"removeOlder": "1",
"removeOlderPoints": "1000",
"removeOlderUnit": "604800",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"useDifferentColor": false,
"x": 1170,
"y": 760,
"id": "06ce1f0bdd299082",
"type": "ui_chart",
"order": 2,
"width": 9,
"height": 6,
"label": "Rms_ACC_mg",
"legend": "true",
"xformat": "HH:mm:ss",
"nodata": "",
"dot": true,
"ymin": "-2",
"ymax": "10",
"removeOlder": 1,
"removeOlderPoints": "",
"cutout": 0,
"useUTC": false,
"colors": [
"#1f77b4",
"#a1bbdd",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"x": 1200,
"y": 840,
"id": "5ea39b32df41862b",
"type": "ui_gauge",
"order": 3,
"width": 9,
"height": 8,
"gtype": "gage",
"title": "Battery",
"label": "V",
"format": "{{value | number:2}}",
"min": 0,
"max": "3.3",
"colors": [
"#ff0011",
"#e6e600",
"#09ca00"
"seg1": "",
"seg2": "",
"x": 940,
"y": 720,
"id": "14458a4b703c0f6e",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "data.battery",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 700,
"y": 780,
"5ea39b32df41862b"
"id": "ee1f5adc2a6ae7ee",
"type": "range",
"minin": "0",
"maxin": "1023",
"minout": "0",
"maxout": "3.3",
"action": "clamp",
"round": false,
"property": "payload",
"x": 670,
"y": 720,
"5ea39b32df41862b"
"id": "81dee7335d1f8620",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" 텐타 1호기 열풍모터 우넘버1 battery 오류 \"\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 660,
"fac60d0bfab12664"
"id": "fac60d0bfab12664",
"voice": "0",
"x": 1190,
"y": 660,
"id": "1e7d1ecfada49883",
"type": "switch",
"name": "data.battery",
"property": "data.battery",
"rules": [
"t": "lt",
"v": "1.5",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 690,
"y": 660,
"81dee7335d1f8620"
"id": "61375eef5be2bacf",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" 텐타 1호기 열풍모터 우넘버1 진동 오류\"",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 620,
"1fd93f5e0ee0d02e"
"id": "1fd93f5e0ee0d02e",
"voice": "0",
"x": 1190,
"y": 620,
"id": "a4cf717d039d6122",
"type": "comment",
"name": "Tenta Unit 1 Hot air motor 5.5Kw (M-4)",
"info": "",
"x": 450,
"y": 340,
"id": "57efb1527c93fcc9",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "red",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 340,
"9009c9d5dd981aa0"
"id": "0f09d3f3065d9b71",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "green",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 380,
"9009c9d5dd981aa0"
"id": "55a45dc0a51160b3",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "red",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 500,
"6216cbdf2da3565a"
"id": "ced39c5519c7c9a1",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "green",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 540,
"6216cbdf2da3565a"
"id": "9009c9d5dd981aa0",
"type": "ui_template",
"group": "da80b0b8087976f8",
"name": "Temp 5.5Kw",
"order": 12,
"width": 3,
"height": 1,
"format": "<style>\n .led {\n position: absolute;\n width: 130px;\n height: 30px;\n margin: 0px;\n border-radius: 1%;\n \n }\n</style>\n<div>\n <span class=\"led\" style=\"background-color: {{msg.payload}};\"></span>\n</div>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"x": 1190,
"y": 340,
"id": "4474bfef90c4cf49",
"type": "ui_text",
"order": 16,
"width": 3,
"height": 1,
"label": "Temp 5.5Kw",
"format": "{{msg.payload.temperature}}",
"layout": "row-center",
"x": 690,
"y": 500,
"id": "849488f8e9219852",
"type": "ui_text",
"order": 24,
"width": 3,
"height": 1,
"label": "Rms_ACC_mg 5.5Kw",
"format": "{{msg.payload.x_rms_ACC_G}}",
"x": 720,
"y": 540,
"id": "6216cbdf2da3565a",
"name": "Rms_ACC_mg 5.5Kw",
"order": 20,
"width": 3,
"height": 1,
"x": 1220,
"y": 500,
"id": "8faaf2e38182fb47",
"type": "ncd-wireless-node",
"connection": "f4bdf3f4b5cd3511",
"config_comm": "f4bdf3f4b5cd3511",
"addr": "00:13:a2:00:42:25:f2:40",
"sensor_type": "80",
"auto_config": true,
"on_the_fly_enable": false,
"node_id_delay_active": "",
"node_id": 0,
"delay": 300,
"form_network": false,
"destination_active": "",
"destination": "0000FFFF",
"power_active": "",
"power": 4,
"retries_active": "",
"retries": 10,
"pan_id_active": "",
"pan_id": "7FFF",
"change_enabled": "",
"change_pr": "0",
"change_interval": "0",
"cm_calibration": "60.6",
"bp_altitude": "0",
"bp_pressure": "0",
"bp_temp_prec": "0",
"bp_press_prec": "0",
"amgt_accel": "0",
"amgt_mag": "0",
"amgt_gyro": "0",
"impact_accel": "0",
"impact_data_rate": "4",
"impact_threshold": 25,
"impact_duration": 1,
"activ_interr_x": 1,
"activ_interr_y": 2,
"activ_interr_z": 4,
"activ_interr_op": 8,
"force_calibration_co2_auto_config": "",
"force_calibration_co2": 400,
"filtering": 0,
"data_rate": 5,
"time_series": 0,
"reading_type": 1,
"mode_80_active": "",
"mode_80": 0,
"measurement_mode_80_active": "",
"measurement_mode_80": 0,
"on_request_timeout_80_active": "",
"on_request_timeout_80": 1,
"sensor_boot_time_420ma_active": "",
"sensor_boot_time_420ma": 0,
"deadband_80_active": "",
"deadband_80": 0,
"filter_80_active": "",
"filter_80": 0,
"output_data_rate_p1_81_active": "",
"output_data_rate_p1_81": 0,
"output_data_rate_p2_81_active": "",
"output_data_rate_p2_81": 0,
"sampling_duration_p1_81_active": "",
"sampling_duration_p1_81": 0,
"sampling_duration_p2_81_active": "",
"sampling_duration_p2_81": 0,
"led_alert_mode_84_active": "",
"led_alert_mode_84": 0,
"led_accelerometer_threshold_84_active": "",
"led_accelerometer_threshold_84": "",
"led_velocity_threshold_84_active": "",
"led_velocity_threshold_84": "",
"acceleration_interrupt_threshold_84_active": "",
"acceleration_interrupt_threshold_84": "",
"set_rtc_101": 0,
"current_calibration_82": "",
"current_calibration_82_active": false,
"current_calibration_c1_80": 178,
"current_calibration_c1_80_active": "",
"current_calibration_c2_80": 178,
"current_calibration_c2_80_active": "",
"current_calibration_c3_80": 178,
"current_calibration_c3_80_active": "",
"output_data_rate_101_active": true,
"output_data_rate_101": "9",
"output_data_rate_101_m2_active": "",
"output_data_rate_101_m2": 0,
"sampling_duration_101_active": true,
"sampling_duration_101": "20",
"sampling_interval_101_active": true,
"sampling_interval_101": "0",
"full_scale_range_101_active": "",
"full_scale_range_101": 1,
"full_scale_range_101_m2_active": "",
"full_scale_range_101_m2": 1,
"x_axis_101": "",
"y_axis_101": "",
"z_axis_101": "",
"low_pass_filter_80_active": "",
"low_pass_filter_80": 0,
"high_pass_filter_80_active": "",
"high_pass_filter_80": 0,
"low_pass_filter_81_p2_active": "",
"low_pass_filter_81_p2": 0,
"high_pass_filter_81_p2_active": "",
"high_pass_filter_81_p2": 0,
"roll_angle_threshold_47": 0,
"roll_angle_threshold_47_active": "",
"pitch_angle_threshold_47": 0,
"pitch_angle_threshold_47_active": "",
"counter_threshold_35": 50,
"counter_threshold_35_active": "",
"payload_length_80_active": "",
"payload_length_80": 3,
"motion_threshold_46_active": false,
"motion_threshold_46": "100",
"x": 400,
"y": 620,
"f63c8cdd374f583a",
"4474bfef90c4cf49",
"849488f8e9219852",
"1e7d1ecfada49883",
"ee1f5adc2a6ae7ee",
"14458a4b703c0f6e",
"32b7525b89b009da",
"15905cf37a1e0c89",
"b290f3aa454e0b43",
"66dcd9d067ca37ab",
"afc4a8483085dfe1"
"id": "15905cf37a1e0c89",
"type": "ui_text",
"order": 4,
"width": 3,
"height": 1,
"name": "Tenta Unit 1",
"label": "Tenta Unit 1",
"format": "",
"x": 690,
"y": 420,
"id": "d179a286befbcd9f",
"type": "switch",
"name": "payload.temperature",
"property": "payload.temperature",
"rules": [
"t": "gt",
"v": "40",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 980,
"y": 420,
"feee90c2fd86775a"
"id": "224d4dd1adddc636",
"type": "switch",
"name": "payload.x_rms_ACC_G",
"property": "payload.x_rms_ACC_G",
"rules": [
"t": "gt",
"v": "10",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 990,
"y": 580,
"61375eef5be2bacf"
"id": "b290f3aa454e0b43",
"type": "switch",
"rules": [
"t": "else"
"t": "lte",
"v": "40",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 720,
"y": 380,
"d179a286befbcd9f",
"57efb1527c93fcc9"
"0f09d3f3065d9b71"
"id": "66dcd9d067ca37ab",
"type": "switch",
"rules": [
"t": "else"
"t": "lte",
"v": "10",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 730,
"y": 580,
"224d4dd1adddc636",
"55a45dc0a51160b3"
"ced39c5519c7c9a1"
"id": "afc4a8483085dfe1",
"type": "ui_text",
"order": 8,
"width": 3,
"height": 1,
"label": "Hot air motor",
"format": "",
"x": 690,
"y": 460,
"id": "3c21fd612631f2ac",
"type": "ncd-gateway-node",
"unknown_devices": true,
"outputs": 2,
"x": 1510,
"y": 320,
"4e5e3b1b3fb6703c",
"707b50bf4cdcfcdf"
"id": "707b50bf4cdcfcdf",
"type": "debug",
"name": "debug 142",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1830,
"y": 220,
"id": "4e5e3b1b3fb6703c",
"type": "switch",
"name": "Limit to Type 80",
"property": "payload.sensor_type",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1860,
"y": 300,
"id": "d9305b3be18578ef",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{ \"tab\": \"A-1\"}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1800,
"y": 120,
"1cb2814b68bb512a"
"id": "5d21112476447df8",
"type": "ui_button",
"order": 25,
"width": 12,
"height": 1,
"passthru": false,
"label": "M-1 motor",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "",
"payloadType": "str",
"topic": "topic",
"topicType": "msg",
"x": 1590,
"y": 120,
"d9305b3be18578ef"
"id": "1cb2814b68bb512a",
"type": "ui_ui_control",
"events": "all",
"x": 2020,
"y": 120,
"id": "e7c58517fc955493",
"type": "ui_group",
"name": "M04",
"tab": "1f029ca2918be483",
"order": 4,
"disp": true,
"width": 9,
"collapse": false
"id": "da80b0b8087976f8",
"type": "ui_group",
"name": "A-1",
"tab": "c79efd6006b924e4",
"order": 1,
"disp": true,
"width": "12",
"collapse": false
"id": "f4bdf3f4b5cd3511",
"type": "ncd-gateway-config",
"name": "usb - do",
"comm_type": "serial",
"ip_address": "",
"tcp_port": "2101",
"port": "COM3",
"baudRate": "115200",
"pan_id": "7FFF",
"rssi": false
"id": "1f029ca2918be483",
"type": "ui_tab",
"name": "A-1",
"icon": "dashboard",
"order": 2,
"disabled": false,
"hidden": false
"id": "c79efd6006b924e4",
"type": "ui_tab",
"name": "Main",
"order": 1,
"disabled": false,
"hidden": false
Now can you reduce the flow, so we can see what nodes we should be looking at.
If you hold down Ctrl and click the nodes they will highlight red, then select export and select the selected nodes, you can reduce to only those required.
Finally also show us the data that enters these nodes by adding debugs to capture the data on entry.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value to any data item.
"type": "group",
"style": {
"fill": "none",
"label": true,
"color": "#a4a4a4"
"nodes": [
"28a1b0ed1013a7c7",
"feee90c2fd86775a",
"f63c8cdd374f583a",
"32b7525b89b009da",
"d57e41cc9271e044",
"e049cc591e54b32c",
"06ce1f0bdd299082",
"5ea39b32df41862b",
"14458a4b703c0f6e",
"ee1f5adc2a6ae7ee",
"81dee7335d1f8620",
"fac60d0bfab12664",
"1e7d1ecfada49883",
"61375eef5be2bacf",
"1fd93f5e0ee0d02e",
"a4cf717d039d6122",
"57efb1527c93fcc9",
"0f09d3f3065d9b71",
"55a45dc0a51160b3",
"ced39c5519c7c9a1",
"9009c9d5dd981aa0",
"4474bfef90c4cf49",
"849488f8e9219852",
"6216cbdf2da3565a",
"8faaf2e38182fb47",
"15905cf37a1e0c89",
"d179a286befbcd9f",
"224d4dd1adddc636",
"b290f3aa454e0b43",
"66dcd9d067ca37ab",
"afc4a8483085dfe1"
"x": 274,
"y": 299,
"w": 1072,
"h": 582
"voice": "0",
"x": 1190,
"y": 460,
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 460,
"28a1b0ed1013a7c7"
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 720,
"y": 340,
"type": "split",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"stream": false,
"addname": "topic",
"x": 670,
"y": 840,
"d57e41cc9271e044"
"type": "switch",
"rules": [
"t": "eq",
"v": "temperature",
"vt": "str"
"t": "eq",
"v": "x_rms_ACC_G",
"vt": "str"
"t": "eq",
"vt": "str"
"t": "eq",
"v": "y_rms_ACC_G",
"vt": "str"
"t": "eq",
"vt": "str"
"t": "eq",
"v": "z_rms_ACC_G",
"vt": "str"
"t": "eq",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 7,
"x": 930,
"y": 800,
"e049cc591e54b32c"
"06ce1f0bdd299082"
"06ce1f0bdd299082"
"06ce1f0bdd299082"
"type": "ui_chart",
"order": 1,
"width": 9,
"height": 6,
"label": "Temp",
"legend": "false",
"xformat": "HH:mm",
"nodata": "",
"dot": false,
"ymin": "0",
"ymax": "40",
"removeOlder": "1",
"cutout": 0,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"x": 1170,
"y": 760,
"type": "ui_chart",
"order": 2,
"width": 9,
"height": 6,
"legend": "true",
"nodata": "",
"dot": true,
"ymin": "-2",
"ymax": "10",
"removeOlder": 1,
"cutout": 0,
"useUTC": false,
"colors": [
"#1f77b4",
"#a1bbdd",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"x": 1200,
"y": 840,
"type": "ui_gauge",
"order": 3,
"width": 9,
"height": 8,
"gtype": "gage",
"title": "Battery",
"label": "V",
"min": 0,
"max": "3.3",
"colors": [
"#ff0011",
"#e6e600",
"#09ca00"
"seg1": "",
"seg2": "",
"x": 940,
"y": 720,
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 700,
"y": 780,
"5ea39b32df41862b"
"type": "range",
"minin": "0",
"maxin": "1023",
"minout": "0",
"maxout": "3.3",
"action": "clamp",
"round": false,
"x": 670,
"y": 720,
"5ea39b32df41862b"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 660,
"fac60d0bfab12664"
"voice": "0",
"x": 1190,
"y": 660,
"type": "switch",
"rules": [
"t": "lt",
"v": "1.5",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 690,
"y": 660,
"81dee7335d1f8620"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 620,
"1fd93f5e0ee0d02e"
"voice": "0",
"x": 1190,
"y": 620,
"type": "comment",
"info": "",
"x": 450,
"y": 340,
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "red",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 340,
"9009c9d5dd981aa0"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "green",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 380,
"9009c9d5dd981aa0"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "red",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 500,
"6216cbdf2da3565a"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "green",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 540,
"6216cbdf2da3565a"
"order": 12,
"width": 3,
"height": 1,
"x": 1190,
"y": 340,
"type": "ui_text",
"order": 16,
"width": 3,
"height": 1,
"x": 690,
"y": 500,
"type": "ui_text",
"order": 24,
"width": 3,
"height": 1,
"x": 720,
"y": 540,
"order": 20,
"width": 3,
"height": 1,
"x": 1220,
"y": 500,
"node_id": 0,
"delay": 300,
"power_active": "",
"power": 4,
"retries": 10,
"pan_id": "7FFF",
"change_pr": "0",
"bp_altitude": "0",
"bp_pressure": "0",
"amgt_accel": "0",
"amgt_mag": "0",
"amgt_gyro": "0",
"filtering": 0,
"data_rate": 5,
"time_series": 0,
"reading_type": 1,
"mode_80": 0,
"deadband_80": 0,
"filter_80": 0,
"set_rtc_101": 0,
"x_axis_101": "",
"y_axis_101": "",
"z_axis_101": "",
"x": 400,
"y": 620,
"f63c8cdd374f583a",
"4474bfef90c4cf49",
"849488f8e9219852",
"1e7d1ecfada49883",
"ee1f5adc2a6ae7ee",
"14458a4b703c0f6e",
"32b7525b89b009da",
"15905cf37a1e0c89",
"b290f3aa454e0b43",
"66dcd9d067ca37ab",
"afc4a8483085dfe1"
"type": "ui_text",
"order": 4,
"width": 3,
"height": 1,
"format": "",
"x": 690,
"y": 420,
"type": "switch",
"rules": [
"t": "gt",
"v": "40",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 980,
"y": 420,
"feee90c2fd86775a"
"type": "switch",
"rules": [
"t": "gt",
"v": "10",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 990,
"y": 580,
"61375eef5be2bacf"
"type": "switch",
"rules": [
"t": "else"
"t": "lte",
"v": "40",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 720,
"y": 380,
"d179a286befbcd9f",
"57efb1527c93fcc9"
"0f09d3f3065d9b71"
"type": "switch",
"rules": [
"t": "else"
"t": "lte",
"v": "10",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 730,
"y": 580,
"224d4dd1adddc636",
"55a45dc0a51160b3"
"ced39c5519c7c9a1"
"type": "ui_text",
"order": 8,
"width": 3,
"height": 1,
"format": "",
"x": 690,
"y": 460,
"type": "ui_group",
"name": "M04",
"order": 4,
"disp": true,
"width": 9,
"collapse": false
"type": "ui_group",
"name": "A-1",
"order": 1,
"disp": true,
"width": "12",
"collapse": false
"name": "usb - do",
"ip_address": "",
"tcp_port": "2101",
"port": "COM3",
"pan_id": "7FFF",
"rssi": false
"type": "ui_tab",
"name": "A-1",
"order": 2,
"disabled": false,
"hidden": false
"type": "ui_tab",
"name": "Main",
"order": 1,
"disabled": false,
"hidden": false
I'm still not sure where to look at.
I'm even unable to spot - in the flow you posted - the node that should display "NO1".
Or can you touch the alarm screen and make it enter the alarm window when the alarm goes off?
[When the alarm goes off, I want to write NO1 error in big letters]
You have multiple dashboard elements in the flow but the photo of your screen only shows
NO1
So...
You need a ui-template node using a large font size to display the message NO 1 Error.
The template node should be on a seperate dashboard tab "ErrorTab".
Use a ui-control node to switch to the ErrorTab
When there is no error condition, replace "No1 Error" with blanks and use ui-control to switch back to the other dashboard tab.
Thank you.
Is there a way to enter the alarm window when the alarm rings by touching the alarm screen?
Use a button.
