Will there be a chance to support Deno (https://deno.land/) in the future?
I would say 'yes' if someone wants to spend the time to figure out a way to do it and they write the code.
Have you tried it? Maybe it works?
Hmm, not off to a good start:
C:\src
> irm https://deno.land/install.ps1 | iex
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 212 100 212 0 0 220 0 --:--:-- --:--:-- --:--:-- 803
tar.exe: Error opening archive: Unrecognized archive format
Deno was installed successfully to C:\Users\userid\.deno\bin\deno.exe
Run 'deno --help' to get started
Stuck? Join our Discord https://discord.gg/deno
C:\src
> deno --help
deno: The term 'deno' is not recognized as a name of a cmdlet, function, script file, or executable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
C:\src
Had to dig for an alternative install. Run as admin:
# Run as administrator:
$env:DENO_INSTALL = "C:\Program Files\deno"
That worked but only runs in the admin powershell window, not in a standard window.
And some quick tests completely failed to run node-red.
