Wireless M-Bus USB dongle problem
I have connected an IMST PA-iM871A Wireless M-Bus dongle to my PC (Windows). I have installed the drivers correctly because the provided software recognizes the USB stick.
Now, I want to connect to an M-Bus device (a gas meter) via Node-Red. For this, I am using the node-serialport (node-red-node-serialport (node) - Node-RED).
The flow consists of a serial in and a serial out node, configured to connect to my USB dongle. This seems to work well because the green 'connected' indicator is on, and it changes to 'disconnected' when I unplug the USB stick from my computer.
What I want to do now is communicate with my dongle. I have tried various methods to send data via an inject node, but nothing seems to work. Can anyone help me figure out how to send a message to the dongle and receive a message from it? (for example, receive the name of the dongle in Node-Red) Thanks in advance
Here is the flow:
"id": "d1b0c0e0.7b6a7",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "e1b0d3f7.a2c4e",
"type": "serial in",
"z": "d1b0c0e0.7b6a7",
"serial": "2aec20f3b4664b5e",
"x": 270,
"y": 440,
"1b0c2e27.6e3ba2"
"id": "1b0c2e27.6e3ba2",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"x": 590,
"y": 440,
"wires":
"id": "261fd38a6e1260a0",
"type": "serial out",
"x": 570,
"y": 360,
"wires":
"id": "0d53a28c830a68d3",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 300,
"y": 360,
"261fd38a6e1260a0"
"id": "2aec20f3b4664b5e",
"type": "serial-port",
"serialport": "COM4",
"serialbaud": "115200",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"dtr": "none",
"rts": "none",
"cts": "none",
"dsr": "none",
"newline": "100",
"bin": "bin",
"out": "time",
"addchar": "",
"responsetimeout": "10000"
I am still trying to get some data in Node-Red from the iM871A-USB - Wireless M-Bus USB-adapter. The adapter is working fine because i checked it via a Analyzer tool in Windows, and i receive telegram messages. But i need the telegrams in Node Red, and tried so many things for almost 2 months right now. Hope someone can help me out! :slight_smile:
It's this device: iM871A-USB - Wireless M-Bus USB-adapter 868 MHz | IMST GmbH
Document about the Host controller interface
I tried to use the serial in / serial out node, connected with an inject node and a debug node. But nothing happens. Hope someone can help me a bit.
You need to send a valid M-Bus frame to the device to communicate with your IMST PA-iM871A Wireless M-Bus dongle in Node-RED. Use a function node to craft the appropriate data (e.g., as a byte array) and send it via the serial out node. The inject node can trigger this action, but ensure you send the correct M-Bus command rather than just a random payload. Use the serial in node to receive responses from the dongle and debug the incoming data with a debug node. Ensure your serial port settings (COM port, baud rate, etc.) match the dongle's configuration. Check the dongle's documentation for specific command sequences.
