Hi there.
I'm new to this world of Node Red and coding in general so bare with me if ask silly questions.
What I have done so far:
[{"id":"d8b6cc0d.873be8","type":"tab","label":"Plate","disabled":false,"info":""},{"id":"351cc5c9.0664ba","type":"inject","z":"d8b6cc0d.873be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"/share/","payload":"/share/BB12345.090930.plate.jpg","payloadType":"str","x":230,"y":200,"wires":[["99e8d71c.058b38"]]},{"id":"eb064ca1.021da","type":"watch","z":"d8b6cc0d.873be8","name":"plate","files":"/share/","recursive":"","x":230,"y":300,"wires":[["99e8d71c.058b38"]]},{"id":"868f4aef.566f98","type":"mysql","z":"d8b6cc0d.873be8","mydb":"bb63b04c.348868","name":"","x":730,"y":180,"wires":[["a3d9d80.21f6b28"]]},{"id":"74d49650.e7f9a8","type":"change","z":"d8b6cc0d.873be8","name":"","rules":[{"t":"delete","p":"topic","pt":"msg"},{"t":"change","p":"payload","pt":"msg","from":"/share/","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":".plate.jpg","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":260,"wires":[["f6500b9e.4a6cd"]]},{"id":"828fbf52.eb7f88","type":"change","z":"d8b6cc0d.873be8","name":"plate","rules":[{"t":"set","p":"topic","pt":"msg","to":"","tot":"date"},{"t":"move","p":"payload","pt":"msg","to":"payload.plate","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":180,"wires":[["a71cc407.822a8"]]},{"id":"f6500b9e.4a6cd","type":"function","z":"d8b6cc0d.873be8","name":"","func":"var plate = msg.payload\nvar date =msg.payload\nvar msg1 = { payload: plate.slice(0, 7)};\n\n\nreturn [ msg1 ];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":260,"wires":[["828fbf52.eb7f88"]]},{"id":"99e8d71c.058b38","type":"delay","z":"d8b6cc0d.873be8","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"2","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":400,"y":260,"wires":[["74d49650.e7f9a8"]]},{"id":"a3d9d80.21f6b28","type":"debug","z":"d8b6cc0d.873be8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":910,"y":180,"wires":[]},{"id":"a71cc407.822a8","type":"function","z":"d8b6cc0d.873be8","name":"","func":"var Plate = msg.payload.plate\nmsg.topic = \"INSERT INTO plate(`Plate`) VALUES ('\"+Plate+\"')\";\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":580,"y":180,"wires":[["868f4aef.566f98"]]},{"id":"bb63b04c.348868","type":"MySQLdatabase","name":"Plate","host":"127.0.0.1","port":"3306","db":"data","tz":"","charset":"UTF8"}]
I take the snapshot file from the LPR camera that ends in my /share folder. Send it to the delay node to kill some double snaps the camera pass (I don't know why) .
Then I remove /share/ and xxxxx.plate.jpg from the payload and then pass it to the SQL.
Now I'm trying to insure that only payload with 2 letters and 5 numbers (AB12345) are sent to the database but I can't figure out how to
