I'm having a small issue with great circle lines.
I don't think it's to look like that. ![]()
Here is the payload.
Kyle
can you paste that payload as a cut/paste rather than an image ? Thanks
{"name":"JR4OZR","lat":"35.064339","lon":"134.145351","ttl":"1200","op":"WV4P","band":"15M","mode":"RTTY","isrunqso":"0","exchange":"JR4 2","section":"","ID":"8b033664350247ad98bb8436755a188c","distance":6614,"iconColor":"#FFFF00","layer":"15M","label":"15M","ismultiplier":1,"greatcircle":[[37.95805,-91.22578],[35.064339,134.145351]]}
solution pushed as v2.27.2
Awesome! Thanks so much.
Try adding to your msg.payload - `"options": {vertices: 25}
actually - I just updated the default to be smoother... v 2.27.3
Thank you. I'm not seeing the update yet in my pallet manager.
should be there now
not sure - I think there must an issue with the underlying library...
looking at it it IS trying to do roughly the right thing given the amount of zoom you have - How does it look if you zoom in so you more or less fit the whole world across the screen ?
Sadly leaflet really doesn't handle anti-meridian crossing well (or at all) so whatever happens it will be a bit hacky.
Here's a link to a flow we discussed last January.
