I want to delete and change color of lines on the Worldmap.
For the color I tried the msg.color:"#4B0082" it stay red, is this the wrong property?
For the deletion of the line I tried msd.delete:"", msd.delete:"true", what is the correct way to delete the line?
Also want to change the line width, can you?
For the flow you need to get a token from https://openrouteservice.org/, the API call I make give you navigation between two points.
Insert it in "Token".
You need to add the "Profile" can be any of Options ""driving-car","driving-hgv","cycling-regular","cycling-road","cycling-mountain","cycling-electric","foot-walking","wheelchair""
Right click on map and add waypoint "Start" and waypoint "End".
Click on "GET NAV"
Rout gets drawn on map
Look at the debug msg "openrouteservice" and there are quit a list of properties.
flows.json (11.4 KB)
