Hi All,
I wanted to plot the GPS satelittes that my GPS sees on world map.
Although my GPS sees 10, it only showed 4 on the map....... Untill I zoomed out.
How can I get them to show them around me, instead of the other (also correct) half of the world?
Please provide a small flow demonstrating the problem.
Generally longitude goes from -180 to +180 - but the map will happily display >180 if you like - so you probably need to "shift" any points with longitudes below 0 . IE add 360 to them to make them +ve.
Thanks dceejay, that works.
if (global.get("Data.Com1.nav.position.dd.lon") < 0 && msg.payload.above.satlng < 0) {
msg.payload.above.satlng += 360;
msg.payload = {
"name": msg.payload.above.satname,
"lat": msg.payload.above.satlat,
"lon": msg.payload.above.satlng,
"icon": "satellite",
"iconColor": "green",
"alt": msg.payload.above.satalt + "KM",
"layer": "Satellite",
"command": {
After your solution, I noticed that when I make a marker on the left of the map I get a negative longitude and on the right side I get a positive longitude.
My added IF statement makes sure the map always shows them near me.
