Hi, i use XBee modules with breadboard on which i can connect sensors and i want to collect this data via Node-red. I saw this video, which use XBee with NR, but don't understand how to collect sensor data from the XBee. Any help?
So what have you tried?
A hint: look for and try with XBee nodes.
A second hint: Manage pallete...
I've try the video above, but i can't see all sethings in the video and can't meke all config's properly.
I try all XBee nodes in NR [Library - Node-RED] , but don't know how to make the right config's.
Please, any help?
Hi, i try this example (xBee transmit and recieve (flow) - Node-RED) again and i've got this in the debug node, but i can't see the message ''Hello'', that supposed to come up (according to the example).
Any idea where is my mistake?
I actually use a PC with Windows 7, in which i connect Xbee
