Connect Wireless Modem with node red and read the data bytes
How can I connect Wireless modem which uses 900hp-S3-pro device with Node red?
I am able to read the data bytes from this device which is receiving the data from Wireless Temperature Sensor in XCTU software serial monitor screen.
But being new with node red, I need some suggestion about how can I read the data bytes and can manipulate it and display the data in a node-red Dashboard.
You posted this in “share your projects” which if you read the description is the place to share completed projects. I have moved it to general.
Have you tried using the serial node?
(I've moved this to 'General' from "Share Your Projects")
Thanks for the help, I have just worked with mqtt nodes and just started with this device
