I hope someone out there can help me. I am a novice at this stuff.
I have Yeelights running on my pi and using node red.
I don not use them all the time so I disable the 2 flows that can control them.
My pi filled up the 32G mem card because of the syslog file and another log file. One was 13 Gigs and the other 15Gigs. 0 space was left on the SD card to run anything.
I have since fixed that and regained some space, but I'm afraid that will keep on happening because Node Red keeps trying to connect to the Yeelights if the flow is running or not.
I have even deleted the flows all together and Node Red keeps trying to connect.
I have posted some of the syslog info to show the messages getting logged.
I would like to know how to stop node red from trying to connect when the flows are not running.
Thanks in advance for any help.
Nov 24 21:18:17 raspberrypi Node-RED[333]: syscall: 'connect',
Nov 24 21:18:17 raspberrypi Node-RED[333]: address: '192.168.0.31',
Nov 24 21:18:17 raspberrypi Node-RED[333]: port: 55443 }
Nov 24 21:18:17 raspberrypi Node-RED[333]: 24 Nov 21:18:17 - [info] [yeelight-compat-hue-config:Yeelight 1] Disconnected from 192.168.0.31:55443
Nov 24 21:18:17 raspberrypi Node-RED[333]: Error at 192.168.0.31:55443 { Error: connect EHOSTUNREACH 192.168.0.31:55443
Nov 24 21:18:17 raspberrypi Node-RED[333]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14)
Nov 24 21:18:17 raspberrypi Node-RED[333]: errno: 'EHOSTUNREACH',
Nov 24 21:18:17 raspberrypi Node-RED[333]: code: 'EHOSTUNREACH',
Nov 24 21:18:17 raspberrypi Node-RED[333]: Error at 192.168.0.33:55443 { Error: connect EHOSTUNREACH 192.168.0.33:55443
Nov 24 21:18:17 raspberrypi Node-RED[333]: address: '192.168.0.33',
Nov 24 21:18:17 raspberrypi Node-RED[333]: 24 Nov 21:18:17 - [info] [yeelight-compat-hue-config:Yeelight 3] Disconnected from 192.168.0.33:55443
Nov 24 21:18:19 raspberrypi Node-RED[333]: 24 Nov 21:18:19 - [info] [yeelight-compat-hue-config:Yeelight 3] Connecting to Yeelight 192.168.0.33:55443
Nov 24 21:18:19 raspberrypi Node-RED[333]: 24 Nov 21:18:19 - [info] [yeelight-compat-hue-config:Yeelight 1] Connecting to Yeelight 192.168.0.31:55443
