I have a flow where I want to add 2 the Yield node to, the first one did want to be connected, were unresponsive to be placed and connected on the flow. Eventual it responded.
The second Yield I can not eve drag onto the flow.
I have tried other nodes like Yaml ,Delay and they all work.
Any ideas??
What module does the yield node come from? It isn't one I've ever seen.
Any errors in the browser console?
I stopped and restarted.
pi@raspberrypi:~/.node-red $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.100:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
1 Aug 12:22:32 - [info]
Welcome to Node-RED
1 Aug 12:22:32 - [info] Node-RED version: v0.20.5
1 Aug 12:22:32 - [info] Node.js version: v8.11.1
1 Aug 12:22:32 - [info] Linux 4.14.98-v7+ arm LE
1 Aug 12:22:36 - [info] Loading palette nodes
1 Aug 12:22:51 - [info] Worldmap version 2.4.1
Initializing chat-platform lib, you should see this only once
Running at: /home/pi/.node-red/node_modules/chat-platform Version: 1.0.9
01 Aug 12:23:00 - [info] RedBot version: 0.18.4 (node-red-contrib-chatbot)
1 Aug 12:23:10 - [info] Dashboard version 2.20.0 started at /ui
1 Aug 12:23:11 - [info] Settings file : /home/pi/.node-red/settings.js
1 Aug 12:23:11 - [info] Context store : 'default' [module=memory]
1 Aug 12:23:11 - [info] User directory : /home/pi/.node-red
1 Aug 12:23:11 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
1 Aug 12:23:11 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
1 Aug 12:23:12 - [info] Server now running at http://127.0.0.1:1880/
1 Aug 12:23:12 - [warn]
your credentials.
1 Aug 12:23:12 - [info] Starting flows
Telegram Bot SignalOwl_2_bot will be launched, environment is development
No context provider specified for chatbot SignalOwl_2_bot. Defaulting to "memory"
1 Aug 12:23:18 - [info] Started flows
------ WebHooks for TELEGRAM----------------
http://localhost:1880/redbot/telegram/
1 Aug 12:23:19 - [info] [sqlitedb:5de16e9e.81da9] opened /home/pi/Documents/AquaData/db/aquadb.db ok
1 Aug 12:23:19 - [info] [sqlitedb:e69770b7.c3e7e] opened /home/pi/Documents/TTN gateway/Gateway request.db ok
The Yield node -
This node sends messages passed from msg.payload separately down the flow. Simply puts the messages in an array and assign to msg.payload.
And the browser console? If the node is misbehaving in the editor, then the browser log is the place to look.
I've not used this yield node but it doesn't look too different to the built-in split node - if you can't get it working, you might want to look at that.
Ps, that yield node is over 4y old - might be abandoned. But you could raise an issue on its repo if you spot the issue.
You drag it into the flow and the log show nothing.
I see it were update like 4 years last. May be I need to look for another node the split a array.
I have edited my post above. I did mean checkout the split node. Very similar functionality (as far as I can tell from the description)
The strange thing is it is in another flow on the same Pi and it works.
Thanks I will use the split node
