I came across a battery powered IR blaster that works via zigbee2mqtt and exposes 6 binary buttons, pretty useful if you have IR devices that you want to control.
I have a ceiling fan that uses IR, putting this thing at some random in line of sight spot saves another remote.
Hopefully my remote(s) are compatible with the signal.
Looks a fun thing to have a play with - ordered one
Just what I've been looking for! Thanks!
Mine has arrived
Just for others - added it into Zigbee2MQTT by inserting pin into reset hole and holding in until it started flashing - rember to put Zigbee2MQTT into Join mode
You should end up with
Click on switch 1 on and select study - point remote at it and press a button
If it's something like tv/on off - I suggest just programming the on and then you can control it by switching it on every time you want to emulate pressing the button
(You can send successive on commands and it will resend the IR code each time)
I programmed the switch 1 off with same code and now I don't seem able to erase/unregister it now
Somehow cannot get it to respond to commands using the MQTT out node!
[EDIT] forgot /set at the end of the topic!!!!!
Do you mind me moving this out of lounge into hardware category so everyone can see it?
@bakman2
Done sir.
The thing is become very valuable to me, works flawlessly for my ceiling fan.
Perhaps you found the solution in the mean time. what worked for me was:
- from registered, put it into study mode,
- then put it back to unregistered.
I just left it
Your solution works for me as well
