I just bought some smartplugs to measure energy of different things.
I paired them succesfull and i can switch them but i dont understand how to read the values described in the link above.
Power (numeric)
Instantaneous measured power. Value can be found in the published state on the
powerproperty. It’s not possible to read (/get) or write (/set) this value. The unit of this value isW.Current (numeric)
Instantaneous measured electrical current. Value can be found in the published state on the
currentproperty. It’s not possible to read (/get) or write (/set) this value. The unit of this value isA.Voltage (numeric)
Measured electrical potential value. Value can be found in the published state on the
voltageproperty. It’s not possible to read (/get) or write (/set) this value. The unit of this value isV.Energy (numeric)
Sum of consumed energy. Value can be found in the published state on the
energyproperty. It’s not possible to read (/get) or write (/set) this value. The unit of this value iskWh.
i tried using the event node but i only get a message every some minutes with an array [0, 0] where the second value is increesing every message.
can some one help me?
Thank you a lot!
