Zigbee2mqtt Node
I have installed the zigbee2mqtt node node-red-contrib-zigbee2mqtt (node) - Node-RED , i have configured my z2m server details , but it is not listing the devices from my zigbee2mqtt server . tried restarting node red service as well .
even if i configure my mqtt username and password it doesn't list any devices .
1
3
You do not mention adding the devices in the bridge node.
I don't use this node. But is Mqtt running on the same server as zigbee2mqtt? Change maybe the host to where your mqtt server is running.
Does it require another node bridge as well ? already i have z2m running on Debian with many devices it won't connect to that ?
Thanks , did the trick switched to MQTT Host IP and all devices are getting listed perfectly .
