Hi
Is it possible to run a Aeotec zwave dongle on Ubutu using node-red without Home Assistant.
Many thanks in advance
Andrew
Hi
Andrew
Hi @fogmajor
Yes!
Disclaimer: I'm the author.
The Serial port must not be in use by any other software, and if you are using Node RED VIA HA - ensure the serial port is mapped correctly, or not use HA at all ![]()
I use Z-Wave JS · GitHub because I prefer to have separate z-wave and mqtt configuration control. I run an instance in Docker and use the NR MQTT nodes to communicate with it via the Mosquitto broker.
Yup!
Zwavejs2mqtt (now Zwave JS UI) and my node above use the same backend Zwave Driver - we're actually all apart of the same dev team ![]()
I don't suppose you could easily (enough) make your nodes work with the standalone package instead of your built-in implementation, could you? I really liked the z2m nodes for the zigbee2mqtt package when I was using it and lamented that I had to use standard MQTT nodes for z-wave.
Hi @LosinIt
ZWave JS is the underlying driver/JS Library that has various implementations using it:
node-red-contrib-zwave-js
Fires up the driver directly in side Node RED (for network maintenance, it has a native Node RED UI)
Unless I don't understand the question (quite possible
) the Node
IS using the standalone package (like zwavejs2mqtt is also using it)
if you mean, you like this set of nodes to use (or offload it's responsibility to MQTT). - I'm afraid that's not the goal of this node.
It's to offer up the Zwave JS library directly inside Node RED with no middleware between it and ZWave JS - Node RED itself is running it.
Or if your referring to accessing the driver instance directly:
V9 (A Woking Progress) exposes the driver functions directly in function nodes
Yes, that's what I mean. I can't give you solid reasoning but I prefer the separation to embedded. It just "feels" better to me.
But that's fine, I've had it all working great for months and there's no need to change it.
No need to explain.
I have the same approach to HomeKit, even though I am a contributor to node-red-contrib-homekit-bridged and close friends with the team behind it, I use an external system for my HomeKit Needs.
Its whatever works for you.
ZWave directly in Node RED works for me, but HomeKit doesn't.
As mentioned earlier, the ZWave JS ecosystem is made up of a few of us.
AI Calzone
Daniel Lando
Brian Howard
And My self
Many thanks for your kind and informative response.
Regards
Andrew
Many thanks for your kind help.
Regards
Andrew
Thank you so much
