I haven't been on these forums long, as I only joined to answer a question from a user, utilising my node.
which brings me on to announcing it.
Is a fully featured, Javascript based, Z-Wave runtime, directly running within node-red.
it has all of the features that you would need to: use, manage and interact with your z-wave devices.
Given it is using a javascript based Z-Wave Driver, it runs in the same memory space as your flows, so its blazing fast, and uitlizes the node red tab API to help with management in a UI based environment.
- 100% Javascript, so it's blazing fast and runs in the same memory space as your flows.
- Does not require a build of any static library
- Stable
- A Built in Node-Red User Interface tab:
- Device Configuration
- CC Value Updating
- Association Management
- Firmware Updating
- Network Map
- Network Actions (Include, Exclude, Heal etc etc)
- 2 Different API models, catering for both experienced and inexperienced users.
- Use one node for your entire network, or a node per Z-Wave device.
- Supports multicast to send commands to mulltiple nodes at the same time.
- Access to all supported CC's provided by Z-Wave JS.
So there you have it, I am actually at V4.3.0 (prepping for V5). - as mentioned, I am new to these forums.
For those looking for Z-Wave support within node-red - Add this to your consideration, you wont be disappointed.
