I copied and pasted my z wave program to control air conditioners from one raspberry to another except that on the copied program I can no longer change the functions on the dashboard. they stay stuck on off
Hi @daak
To clarify, is this a problem with the ZWave Module (Which I am the author of) or a problem with Dashboard?
Also, what do you see if you open a command window and run
node-red-stop
node-red-start
Copy/paste the output here please, not screenshot.
It's worth noting, if you have moved to a different machine without copying your ZWave network data files - then the module has to re-scan / learn the network.
Devices in the side bar UI will have a thumbs up - once they have been learned about
i have a problem with the dashboard. For example, I can't put the controls on On, it remains stuck on Off. I can't also modify it, add a line or delete it.
but I can see the devices with a thumbs up.
