using Node Red, I have a series of lights and smart plugs (that have lights plugged into them) that I toggle when it's dawn or dusk. Occasionally, a light will not toggle correctly. For example, 1 of my 3 devices will be in the "ON" state during the day when the flow should have turned them all off. All of these lights are zwave controlled through zwavejs2mqtt. I assume the light isn't toggled because of some intermittent zwave issue, but that's speculative. I don't know the real reason. Is there a way to build "retry" logic into my NR flow so that if a light fails to switch, I can keep trying it until it does?
If invoking the "turn_on" or "turn_off" service doesn't propagate zwave failures, I'm not sure how to address this.
