Zwave understanding
I could really do with a bit of guidance please
I have a Fibaro-101 push button
When i press it twice i get the following
msg.payload : Object
object
event: "VALUE_NOTIFICATION"
timestamp: 20/04/2026, 13:53:45 [UTC+1]
nodeId: 24
nodeName: "Push Button"
nodeLocation: undefined
eventBody: object
valueId: object
commandClassName: "Central Scene"
commandClass: 91
property: "scene": "001"
propertyName: "scene"
propertyKeyName: "001"
value: 3
I have written a if statement to capture the value:3 but it doesn’t seem to work.
Any help would be appreciated
Many thanks
Andrew
What happens if you use a switch node to compare msg.payload.value and (numeric) 3, the output connected to a debug node?
Hard to help with limited info, showing us the if statement, and a proper output from the debug sidebar copy value, would make it clearer.
But guessing the value 3 would be in
msg.payload.eventBody.value
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
For value_notification
It’s msg.payload.eventBody.value
See below manual
As its value is only good at time of event for this event type. hence its neither prevValue or newValue :grin:
Ie its not stateful
Hi
I used the switch node which help me understand the concept.
Thank you for you help
Andrew
Hi
I did not know the trick of the side bar it help me greatly
Thank you Andrew
Hi Marcus
Yet again you helped me so thank you
I do try and resolve issues but after a few hours of getting anywhere its time to call for help
Thanks again
Andrew
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You may well learn more useful stuff.
Thank you
This is my attempt
Dependent off the number of presses from the Fibaro switch (2 for on - 3 for off)
The function then calls the Shelly power plug and turns on/off
Function
Thank you for your help
if (msg.payload.eventBody.value == '3') {
    msg.payload = true;
else if (msg.payload.eventBody.value == '4'){
    msg.payload = false;
var onoff = msg.payload /*trigger*/
const _nodeId = 23;             /* Target Node */
const _value = onoff;            /* Value */
const _valueId = {
    "commandClassname": "Binary Switch",
    "commandClass": 37,         /* Binary Class */
    "endpoint": 0,              /* Target End point - The device might have 2 binary switches */
    "property": "targetValue",  /* Property */
const Message = {
    payload: {
        cmd: {
            api: 'VALUE',
            method: 'setValue'
        cmdProperties: {
            nodeId: _nodeId,
            valueId: _valueId,
            value: _value
return Message;
Sorry - ignore the above (now deleted)
Yes that will work :ok_hand:
(I’m in work - so little chaotic :grin:)
But the minimum for a Value ID only needs
  • endpoint
  • commandClass
  • property
  • propertyKey (sometimes - CC Dependant)
The other bits is just metadata
Hi Marcus
Thank you for your help, It took me a while but i got there in the end
When you get a minute could you strip out what is unnecessary in my function?
Thank Andrew
Hi @fogmajor
What you have will work, but V11 aims to adhere to the "low code" nature of Node RED, so I should be a good teacher here really :smiley:
You can achieve the above with No Function Node in site, and making use of the new features.
Just Select your Controller in the Device Nodes (might need to reselect the Fibaro Node)
[{"id":"8019ba233b043ced","type":"zwavejs-device","z":"42a07040073c9b0e","name":"Fibaro-101","runtimeId":"","nodeMode":"Multiple","filteredNodeId":"24","dataMode":"R","outputs":1,"inputs":0,"x":230,"y":330,"wires":[["f51bf59441a7d8f0"]]},{"id":"f51bf59441a7d8f0","type":"zwavejs-splitter","z":"42a07040073c9b0e","name":"Filter To Central Scene Event","splits":[{"valueId":{"commandClassName":"Central Scene","commandClass":91,"endpoint":0,"property":"scene","propertyKey":"001","propertyName":"scene","propertyKeyName":"001"},"index":0,"name":"CENTRAL_SCENE.SCENE.001"}],"outputs":1,"x":320,"y":380,"wires":[["cf3e9bf0adc814a6"]]},{"id":"575db43b94cdf478","type":"zwavejs-factory","z":"42a07040073c9b0e","valueSetOptionsType":"json","valueSetOptions":"{}","valueType":"jsonata","value":"payload.eventBody.value = 3 ? true : false","valueIdType":"json","valueId":"{\"commandClass\":37,\"endpoint\":0,\"property\":\"targetValue\"}","argsType":"json","args":"[]","endpointType":"num","endpoint":0,"nodeIdType":"num","nodeId":"23","trackingIdType":"msg","trackingId":"id","name":"Create Binary Command","api":"VALUE","method":"setValue","commandClass":"","x":420,"y":470,"wires":[["917ae72f4947e849"]]},{"id":"cf3e9bf0adc814a6","type":"switch","z":"42a07040073c9b0e","name":"Value Between Between 3-4","property":"payload.eventBody.value","propertyType":"msg","rules":[{"t":"btwn","v":"3","vt":"num","v2":"4","v2t":"num"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":430,"wires":[["575db43b94cdf478"]]},{"id":"917ae72f4947e849","type":"zwavejs-device","z":"42a07040073c9b0e","name":"Sonos-Kitchen-Power","runtimeId":"","nodeMode":"All","filteredNodeId":"","dataMode":"S","outputs":0,"inputs":1,"x":650,"y":470,"wires":[]}]
This uses the power of the Event Splitter, Switch and CMD Factory Nodes (using JSONata)
Hi Again
I am trying to understand the different messages returned from various zwave devices
The one i am struggling with is a Fibaro PIR. Is it possible to detect when the new value changes
from 0 to 255 using a simple function to start with ?
Thank you in anticipation
object
event: "VALUE_UPDATED"
timestamp: 1777244644479
nodeId: 19
nodeName: undefined
nodeLocation: "Pir"
eventBody: object
valueId: object
newValue: 255
prevValue: 255
That does sound very simple to achieve in a function.
Since a function node does not retain knowledge of message contents once it has processed them you probably need to store msg.payload.newValue in context for comparison when the next message arrives.
One of the videos that @Colin pointed out covers context, but it perhaps goes into too much depth for a newcomer.
A couple of questions:
  1. In the sample data you posted there is a key prevValue. Can you not compare this with newValue to spot the value change?
  2. Are 0 and 255 the only possible values, or might newValue in successive messages be eg 0, 10, 100, 255?
  3. Why do you seek to restrict our responses to the function node? Have you sufficiently explored the standard nodes?
  4. What have you tried, and what problems did you encounter?
Hi and thank you for your prompt response.
To answer your questions, I am a beginner when nodered is concerned and am learning the basics of zwave.
I have a zwave stick (usb) AEOTEC and have set up the latest zwavejs with the help of Marcus.
I am trying to understand the messages that come from various zwave devices. I have been partially successful trying to understand the parts of messages.
With respect to my current problem i try to extract the newValue and prevValue from a fibaro pir as my previous post but it returns undefined.
Thanks again Andrew
Use a debug node set to output the complete msg object
Send the VALUE_UPDATED message from node-red-contrib-zwave-js to the debug node.
Use the "Copy value" button in the debug pane
And paste the data here.
Thank you it works a treat
