A single pc on Window 10 (64 bits) is installed with node-red locally and connected with router via wifi dongle. The function of Node-Red is to communicate via MQTT protocol with many raspberry pi's and collects data. The pc ip is 192.168.1.10. It's running locally without an internet connection.
Today, this pc is connected to the server via LAN connection, on IP address 10.23.1.110 for monitoring purpose. The system is able to response on this IP address.
This cause the node-red hang as shown in below picture
After I unplug the LAN cable and restart the pc the node-red works
How I can fix to localhost to run the node-red.
