Acionando dispositivo do Node-Red com Grafana
Good evening, does anyone know if it is possible to add a button in Grafana to trigger any device connected to Node-Red?
I have a PLC S7-1200 connected to Node-Red and I'm using Grafana to visualize the data. Is it possible to perform some activation on the PLC with Grafana?
If I remember correctly there is an mqtt plugin for grafana, so you send a command using that.
