Adding Firebase JavaScript SDK's to Node-red results in error 'ERR PACKAGE PATH NOT EXPORTED'
Hi everyone,
earlier this week I created this post asking if it is possible to add JavaScript Firebase SDK's to Node-red. I got redirected to official Node-red docs and also to this example.
I got the example working as seen in the picture below:
But now when I wanna start the Node-red with Firebase SDK's I get an error:
This is my settings.js file:
I know for sure that the latest Firebase SDK's is installed locally in Node-red:
I would be helpful for any help really!
Thank you in advance.
Looking at their documentation, you require firebase/app, not firebase.
See here for their docs.
Wow! Now it doesn't generate any errors and I can load the basic flow and dashboard!
I will try immediately setting up a Firebase code and try connecting to database! But I think it will work now! :fire:
Please I need help with something.
Firebase JavaScript SDK's are tree shakable, so I need to import modules by their name like in the example from their docs below:
How can I reproduce this behavior inside functionGlobalContext?
Also please - what am I getting when I call now inside a Node-red function this code:
var firebase = global.get('firebase');
var firebaseDatabase = global.get('firebaseDatabase');
Do I now need to write:
const {initializeApp} = require(firebase);
When I log the firebase object I get this:
Without knowing anything specific about Firebase, the object returned by require('firebase/app') has a lot of functions defined on it that you can use.
The code:
const { initializeApp } = require('firebase/app');
is one way to load just the functions you want to use.
But you don't have to do it that way. You can still require the whole firebase/app module and then call the functions it provides:
const firebaseApp = require('firebase/app');
// Call `initializeApp`:
firebaseApp.initializeApp( ... )
And the same will be true of firebase/database.
So you can do the requires in functionGlobalContext just as you show. Then in your function node, you would do:
const firebaseApp = global.get('firebase');
firebaseApp.initializeApp( ... );
This is code snippet on how to initialize Firebase from their docs:
In order to achieve this I need to setup my settings.js file like this:
firebase: require('firebase/app'),
firebaseDatabase: require('firebase/database')
And in my function I need to call this:
const firebase = global.get('firebase');
const firebaseDatabase = global.get('firebaseDatabase');
const firebaseConfig = {
//my config
const app = firebase.initializeApp(firebaseConfig);
const database = firebaseDatabase.getDatabase(app);
Do I get it right or I did a mistake somewhere?
That looks like it would work - assuming it behaves as their docs suggest.
Yes it works! I can even now write data into the database!
Thank you a lot man - you just saved me :heart:
