What can i do with these message?
http://192.168.0.129:1880/#flow/cb6f77f6.8fa118 is niet bereikbaar.
ERR_ADDRESS_UNREACHABLE
Do I lost my flow?
Jack
Do I lost my flow?
Jack
How did you try to start Node-RED?
Is anything else showing on the log?
What version of Node-RED are ou running?
What platform are you running on?
Hoe heb je Node-RED geprobeerd te starten?
Staat er nog iets in het logboek?
Welke versie van Node-RED gebruik je?
Op welk platform draai je?
Dear Sir,
Thank you for your answer.
At the moment I do not reach the Node-Red application at all.
Therefore, it is not easy to find the requested data correctly.
· I am starting, as before, from a shortcut with the following characteristics :
· I find these logs, which of these do you want?
· I noted earlier on11.04.2020 Version 1.2.7.
· I suspect by platform you mean Raspburry PI+.
Thanks for your kindness.
Jack De Gendt
On the pi, open a terminal window and enter
node-red
And press enter. That should start node-red
Wow, I do it. I am curious and message you.
Dear,
First of all, thank you for the quick and positive treatment of my question and the helpful answer.
Indeed, I have access to Node-Red again, for which I thank you.
However, I waited so long to respond because I had a difficult question to formulate.
I have since found the solution myself.
Still, I would like to ask : what is the relation between Node-Red and the Fred Node-Red (Fred Short) please ?
Kind regards,
Jack
Translated with DeepL Translate: The world's most accurate translator (free version)
