According to the documentation, the alexa-home node sends the IP address of the Echo device that initialized the message.
This can be found under msg.alexa_ip.
The problem in my case is that I never get an IP.
The value is always "undefined" - in any case, no matter if the message is triggered by a routine or directly by an echo device.
I use the latest version 2.0.0 of the node, but also with earlier versions I had no success.
Is there any special constellation that is necessary to fill the IP address correctly?
Echo Dot 2, Echo Dot 3, Echo Dot 4, Echo Plus 2, Echo 2, Echo 3, Echo 4
Node-RED version: v2.2.2
Node.js version: v14.18.2
it's the official docker image nodered/node-red:latest which i start with the following docker-compose.yml:
version: '3.5'
services:
node-red:
image: nodered/node-red:latest
user: root
network_mode: "host"
expose:
- "80"
- "1880"
- "60000"
- "3456"
- "3457"
- "4200"
cap_add:
- NET_ADMIN
restart: unless-stopped
volumes:
- "./data:/data
both - the controller for basic settings and the other ones for interaction with Alexa.
Everything has also been working as it should for years - only the IP is not provided.
alexa-home-controller: Port = 80, MaxItems = 100, no "use node as webserver"
alexa-home: the device name and all the 3 types (mostly dimming)
As I said - everything works fine except for the IP.
Nothing is printed - no error is thrown.
Yes, of course - but none that I would somehow associate with the alexa-home IP issue.
The debug log on the web ui is empty.
Ok I'm ot going to be abe t help since I do not use docker and have no experience with it. Hopefully soeone else will be able to give you an idea or you could open an issue with the node-red-contrib-alexa-homes author on it's GitHub issuespage
