Hi guys,
How to make all tabs titles or at least tab icons visible all times?
It’s annoying to click 3-line menu button every time the tab switch is required.
And related question: Is there a keyboard shortcut to switch between tabs?
Thank you!
Hi guys,
Thank you!
No simple way i’m afraid. On touch devices you can enable swipe left or right.
You can also create some buttons and use a ui_control node and inject msg.tab with either +1 or -1 to go to next or previous
That’s pretty cool and good enough. Thank you.
Details (for other newbie like me):
Add 3 UI button nodes to the flow.
Add 1 ui_control node to the flow.
Wire buttons out to ui_control in.
Enter each button and type following into each field of each button accordingly:
Common properties.
Group --> Choose Buttons group (if not existing, create Buttons group per each tab).
Size --> 1x1
Leave other field empty except following:
For Next button:
Icon --> arrow_forward
Payload --> type String, value: +1
Name --> Next
For Previous button:
Icon --> arrow_back
Payload --> type String, value: -1
Name --> prev
For refresh button:
Payload --> type String, value: ""
Name --> refresh
