I download the sample to test the jump Tab 1 and Tab 2.
Everything fine.
After I adding a Table as Tab 3 and adjust the Tab 3 layout, the dashboard no longer display
Tab 1 & Tab 2 selection. It only show Tab 3 table.
After I delete the Table and deploy, then the dashboard is empty.
The Tab 1 and Tab 2 item not show.
What mistake I make?
Actually I want to create a Table 1 in Tab 1, Table 2 in Tab 2, Table 3 in Tab 3.
How to do that? Anyone got some sample?
edit:
I had try to delete the ui_base because the Tab 3 look like replace the ui_base.
How to get back the ui_base? I deploy and not show up anymore.
Nodered version v3.1.7
Node.js version v20.11.1
dashboard version 3.6.5
The burger icon missing after I deploy the table dashboard.
Before adding the table, the burger icon function normally. Can choose Tab 1 and Tab 2.
After add Table in Tab 1 no more burger icon. Only show Tab 1.
Delete the table and deploy, no more dashboad icon display.
I find out that is all Tab is table then ok. But if I add a new Tab for gauge, it won't display at the Tab column for selection. Anyone know what mistake I make?
Ok, so in the EDIT window where you are making these things....
What is set there?
(eg)
Oh, and just to let you know:
As you are new here, you are limited to how much you can post.
PLEASE don't waste replies. You can EDIT a posted reply if you need to add more.
Just mark it as edited (with words) so people know you have edited it.
Anyone got the solution? After add in table the Tab missing. Only show table. Other Tab for Gauge, text all cannot show. After delete the table and deploy, the dashboard show nothing, request to add UI node.
After delete the table, I had compare previous running ok without table flow.json file with after add in table and remove table flow.json file. both file is same. But after delete the table no more UI node display in dashboard.
Ok, I can understand the top part of the flow shown on the EDIT screen.
What is the show / hide tab 1 bit all about?
You have a button and straight after a switch node.
The button can only send ONE THING. It can't change so I am confused what the switch is doing.
What happens if you click on the Group 1button above the table as shown in the last picture of the dashboard with the table showing? OK, there are more pictures after it.
(Doing catch up with what you posted since)
(Disclaimer - I haven't got your flow. Not keen on loading foreign flows.)
You will have to examine some settings more than you have already.
eg:
All working, look at the dashboard settings and see if the Always show side menu setting is.
Then, break it and check if that setting has changed.
There is 3 options.
If it changes to ..... Oh, ok. Maybe not.
(To anyone else)
Is there a way to disable access to the tab menu?
But I feel SOMETHING is changing and you need to find what it is.
