So, as a temporary workaround, I've built this flow to use the admin API to install the local package:
[{"id":"f1a0c0de03","type":"inject","z":"f1a0c0de01","name":"Install from folder","props":[{"p":"modulePath","v":"/src/node-red-contrib-uibuilder","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":120,"y":120,"wires":[["f1a0c0de04"]]},{"id":"f1a0c0de04","type":"function","z":"f1a0c0de01","name":"Build JSON request","func":"const modulePath = msg.modulePath;\nif (!modulePath) {\n node.error('msg.modulePath is required', msg);\n return null;\n}\n\nmsg.payload = { module: modulePath };\nmsg.headers = {};\n\nconst base = (env.get('NR_ADMIN_URL') || 'http://localhost:1885').replace(/\\/+$/, '');\nmsg.method = 'POST';\nmsg.url = `${base}/nodes`;\n\nconst token = env.get('NR_ADMIN_TOKEN');\nif (token) {\n msg.headers.Authorization = 'Bearer ' + token;\n}\n\nnode.status({ fill: 'blue', shape: 'ring', text: 'installing...' });\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":120,"wires":[["f1a0c0de08"]]},{"id":"f1a0c0de08","type":"http request","z":"f1a0c0de01","name":"POST /nodes","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":580,"y":120,"wires":[["f1a0c0de09"]]},{"id":"f1a0c0de09","type":"function","z":"f1a0c0de01","name":"Format result","func":"const body = msg.payload;\n\nif (msg.statusCode === 200 && body && body.name) {\n node.status({ fill: 'green', shape: 'dot', text: body.name + '@' + body.version });\n msg.payload = {\n installed: body.name,\n version: body.version,\n nodes: (body.nodes || []).map(n => `${n.id} [${(n.types || []).join(', ')}]`)\n };\n return msg;\n}\n\nconst hints = {\n 401: 'Not authorised - set NR_ADMIN_TOKEN to a valid bearer token',\n 404: 'Not found - check the URL / httpAdminRoot, and that palette editing is enabled'\n};\n\nnode.status({ fill: 'red', shape: 'ring', text: 'failed (' + msg.statusCode + ')' });\nmsg.payload = {\n error: true,\n status: msg.statusCode,\n hint: hints[msg.statusCode],\n detail: body\n};\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":120,"wires":[["f1a0c0de0a"]]},{"id":"f1a0c0de0a","type":"debug","z":"f1a0c0de01","name":"Install result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":120,"wires":[]}]
However, I'm not sure whether something has changed with Node-RED v5.0.9?
Previously, an Editor plugin would definitely run BEFORE any node Editor code is run. This no longer seems to be the case, my Editor plugin is running AFTER which is very much messing things up.
Not sure if this is something I've done in my code or whether something has changed in Node-RED?
