I've dropped a quick flow:
This works around the fact that you cannot install Nodes to the palette from a local folder via the Palette Manager even though it uses npm under the skin which does allow that and more. See also "Allow more flexible installation via the palette manager + maybe a breaking change in the Editor?"
This saves you from having to drop to a command line to do the install and is really useful when you want to test what happens when users install your nodes using the Palette Manager or the admin API.
