What alternative are there to a PI, to run Node-red on. Need to be the same, just about, as a Pi Zero.
I have one flow with 15 nodes handling about 10 messages per hour, so really low consumption
Thank you
Thank you
Possibly now partly depends on what you need to do in Node-RED. For example, the MCU version of Node-RED can run on an ESP32 and some of those seem not far off the power of a Pi Zero in terms of raw performance. Though obviously very different underlying OS's so they won't always be good at doing the same things. Better at some and worse at others.
Thank you, I will look into that.
