Hello everyone,
We just released the first nodes for Microsoft Jacdac (https://aka.ms/jacdac). Jacdac is a bus-based plug-and-play hardware and software stack for microcontrollers and their peripherals such as sensors and actuators.
In this (beta) release, there are two nodes that allow to listen for events and sensor readings. Since Jacdac is plug-n-play you can use a single node to capture a whole range of devices and pipe their data into your flows. You can do things like send me all down events for any button on the Jacdac bus or stream any humidity sensor on the bus.
Defintely looking for feedback on the design of the nodes, to make sure we match the typical expectations and usage patterns from the node-red platform.
