[ANNOUNCE] node-red-contrib-zwave-js 6.2.0
unfortunately no success :frowning:
did you use the command or via the UI?
The command I pasted up top - is detached from the UI, so the UI wont realise there is a change.
Any config changes I will use the UI, as that includes a poll after it has been set.
this parameter should switch from Fahrenheit to Celsius.
It still shows Fahrenheit.
ok,
Are you doing this in the UI or a command?
also are you waking up the device after?
if the device sends data eg. temp it should be awake?
You would think right?
but actually no,
a wake up interval is different to a device reporting values.
a wake up interval is to receive new config values (and to report batter levels)
usually there is a method (as per device manual) to wake up the device - usually like a press on a button of some sort
from the manual on your device.
To wakeup the device please perform the following action: There are two tamper keys in the device, one is in the back side, another is in the front side.Both of themcan add,remove, reset or association from Z-Wave network.Press any key once, the device will awake 10 seconds.
Commands are queued, until the device sends a wake interval - as that is when the device is asking for any config changes
Super, it works.
Thaks a lot
You are very welcome.
Also Note:
Our device configs have the ability to split bit mask type params into their seperate values,
just that this device config isn't set up to do so (yet)
we have a few devices that use bit masks - just that some need to be updated.
Hi Marcus,
I just want to tell you that I like your zwave-js very much! Great job and great improvment over openzwave!
I have now integrated 14 devices (switches, door window sensor, thermostats, sirene, Key Fobb, 3in1 sensor) without any problems.
Thank's for shareing!
Hannes
Great to know @juntiedt.
I have something in the works for this node (and maybe 1 or 2 minor fixes of course).
Keep an eye out! :grinning_face_with_smiling_eyes:
I played with the system and started refresh property list for one thermostat.
it now shows fechting properties ..... for all devices
and nothing happens.
How long will it take?
I don't get temp and other updates anymore
ZWaveError: Failed to initialize the driver: Error: Failed to lock DB file "/home/pi/.node-red/zwave-js-cache/f65e5828.values.jsonl"!
at JsonlDB.open (/home/pi/.node-red/node_modules/@alcalzone/jsonl-db/src/lib/db.ts:229:10)
at Driver.initValueDBs (/home/pi/.node-red/node_modules/zwave-js/src/lib/driver/Driver.ts:909:3)
at Driver.initializeControllerAndNodes (/home/pi/.node-red/node_modules/zwave-js/src/lib/driver/Driver.ts:948:4)
at Immediate. (/home/pi/.node-red/node_modules/zwave-js/src/lib/driver/Driver.ts:817:5) (ZW0100)
"Error: Node 12 does not exist."
"Error: Node 13 does not exist."
"Error: Node 14 does not exist."
all thermostats are gone
sorry for my last post!
stopping Node-red and starting again fixed the problem.
Another question:
I cannot set the setpoint of my thermostat. With the UI it works but not though a command
I have included the command of openzwave:
return {topic:"setValue", payload: {"nodeid":11,"cmdclass":67,"type":"decimal","genre":"user","instance":1,"cmdidx":1,"label":"Heat","units":"C","value":"22.0"}};
looks like valueAPI
Hi @juntiedt
This is not a payload that I know of - this looks like openzwave format.
In this module:
Change the set point in the UI (but open up UI Monitor, before you do, to see the command.)
This will allow you to see (and use) the command later - changing the value as necessary :+1:
This will show you the ValueID version.
And the CCAPI Version.
let Message = {
    payload: {
        mode: "CCAPI",
        node: <Node ID>,
        cc: 0x43,
        endpoint: 2, /* if needed */
        method: "set",
        params: ["Heating",TargetValue, 0x00] /* 0x00->C, 0x01->F */
return Message
Heating refers to set point type.
"Heating"
"Cooling"
"Furnace"
"Dry Air"
"Moist Air"
"Auto Changeover"
"Energy Save Heating"
"Energy Save Cooling"
"Away Heating"
"Away Cooling"
"Full Power"
Edit:
Just noticed that you are including an OZW command, not actually using that command :laughing:
zwave-js uses lock files to protect the value database, and the lock was not released gracefully.
Could have been cutting the power to the system without terminating node-red for instance.
the fact you seen this, means the lock file had done its job at stoping the database being corrupted.
I used the value API. It works.
I did not try the Ozwave command. This was just to give you an idea of my problem.
Thank's again
No worries,
I noticed after, you referenced it. :+1:
one last question to the Value API.
What has to go into the options?
Should this be the meta data that you get when you click in the UI?
Hi @juntiedt,
The ValueAPI works with a ValueID
However, despite its name, it's not an ID per se.
It's an object that instructs the ValueAPI to what CC, Endpoint and property a value belongs to
Full Example.
/* To get a ValueID: Double click the title of the value in the UI */
const MyValueID = {
/* Options is optional and only applies to setValue */
const Options = {
    transitionDuration:"1m10s", // Multilevel Switch
    volume: 30 // Sound Switch
const MyTargetValue = 50
const  Message = {
    payload: {
        mode: "ValueAPI",
        node: 2,
        method: "setValue",
        params: [MyValueID, MyTargetValue, Options]
return Message
Here is the Wiki for ValueAPI (and the other APIs)
Hi Marcus,
how can I make a Multi Level Sensor Report incomming?
This is the case when theThermostat should use an external temp sensor.
This is the one that goes out:
valueId: {
commandClassName: "Multilevel Sensor",
commandClass: 49,
endpoint: 0,
property: "Air temperature",
propertyName: "Air temperature"
meta: {
type: "number",
readable: true,
writeable: false,
unit: "°C",
label: "Air temperature",
ccSpecific: {
sensorType: 1,
scale: 0
propertyid: "0-49-Air temperature-",
endpoint: 0,
valueData: {
value: 18.84,
unit: "°C"
