So,
Its been a while since I have been able to work on this project. Long storey short, workhorse got deaded, got new workhorse.
Now I have a new machine (an M1 Apple Product if your interested)
I present node-red-contrib-zwave-js 6.4.0.
6.4.0 focuses on the final implementation of S2 security, in the form of Smart Start
That's right! you can now add your devices to the network using only its QR Code.
Testing shows, doing this on a large number of devices can cause USB sticks to struggle with bandwidth - especially when all your Smart Start devices are trying to get interviewed at the same time - so keep that in mind - Do Smart Start includes one at a time (allowing devices to fully interview)
Here is the gist for 6.4.0:
Fixes
- When a new node appears in the UI list after it gets added to the network, its battery is correctly reported.
- Fix potential crash, if Remove Failed Node is called twice for the same node.
- Device nodes now clone the received network message, removing a situation where filter node outputs,
are affected by other device nodes having the same interest in the object. - Account for 3 digit node ID's in UI
- Fixed
event-filterignoringstrictmode
New Features
- Implemented Zwave S2 Security Smart Start.
This includes a new mobile UI, allowing you to use it as a device inclusion tool. - Expose further driver timeout options
Changes
- Controller ready checks are now made prior to showing any UI modal form, that may depend on the controller.
- The battery icon in the node list is now updated, whenever a device transmits an update.
- JSON Keys are now quoted in the UI monitor
- The timestamp value in event messages are now the time in milliseconds from the unix epoch
- Bump ZWJS to 8.8.2
- Bump serial port to 9.2.8
Enjoy!
