Audio out Node, error "not allowed"
Hi
my question, when I get this Error "not allowed" and why sometimes this function works?
the alarm will be generated at the first link the date/time has the same value 3 times "no data/update" and the second link is a Alarm (false/true) "no Battery/charge"
        "id": "637d2bdf.cba3ac",
        "type": "function",
        "z": "998f3d00.013738",
        "name": "Alarm1",
        "func": "var timebefore = flow.get('timebefore');\nvar newtime = msg.payload;\nvar count = context.get('count')||0;\n\n//node.warn(\"last time: \" + timebefore);\n//node.warn(\"time aktuell: \" + newtime);\n\nif(newtime === timebefore) {\n    count += 1;\n    context.set('count',count);\n}\n    else {\n        count = 0;\n        context.set('count',count); \n    }\n\nif ( count === 3 ) {\n    \n    msg.alarm = true;\n    count = 0;    \n    context.set('count',count);\n}\n    else {\n        msg.alarm = false;\n    }\n    \nmsg.count = count   \ntimebefore=newtime;\nflow.set('timebefore', msg.payload);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 280,
        "y": 580,
                "4b631511.8bd004",
                "3daa8f10.ed8258"
        "id": "3daa8f10.ed8258",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 470,
        "y": 520,
        "id": "34c56514.13ff6a",
        "type": "link in",
        "links": [
            "ac421d25.aa4088"
        "x": 155,
        "y": 580,
                "637d2bdf.cba3ac"
        "id": "4b631511.8bd004",
        "type": "switch",
        "name": "Meldung",
        "property": "alarm",
        "propertyType": "msg",
        "rules": [
                "t": "true"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 440,
        "y": 580,
                "f9ef1873.a934d8"
        "id": "b0c8f61c.c78218",
        "type": "ui_toast",
        "position": "dialog",
        "displayTime": "3",
        "highlight": "",
        "sendall": true,
        "outputs": 1,
        "ok": "OK",
        "cancel": "",
        "raw": false,
        "topic": "",
        "name": "WeatherData FAIL",
        "x": 830,
        "y": 640,
                "40b60915.6cf19"
        "id": "2d5fc592.6ab3e2",
        "type": "inject",
        "topic": "",
        "payload": "145",
        "payloadType": "num",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 130,
        "y": 760,
        "id": "4ab9d7d7.3b1c4",
        "type": "template",
        "name": "Alarm1",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "Attention attention please \nno Data - update\nno Data - update any more",
        "output": "str",
        "x": 600,
        "y": 640,
                "a36d9476.1c27b8",
                "b0c8f61c.c78218"
        "id": "e9399b1b.2ce83",
        "type": "inject",
        "name": "Test",
        "topic": "",
        "payload": "Test",
        "payloadType": "str",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 390,
        "y": 640,
                "f9ef1873.a934d8"
        "id": "f2903da.de4484",
        "type": "link in",
        "name": "Batt Alarm",
        "links": [
            "a404769b.a1c1e"
        "x": 655,
        "y": 700,
                "a36d9476.1c27b8"
        "id": "40b60915.6cf19",
        "type": "function",
        "name": "reset",
        "func": "msg.reset = true;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1050,
        "y": 640,
                "f9ef1873.a934d8"
        "id": "f9ef1873.a934d8",
        "type": "trigger",
        "op1": "Meldung",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "-3",
        "extend": false,
        "units": "min",
        "reset": "",
        "bytopic": "all",
        "name": "Alarm",
        "x": 590,
        "y": 580,
                "4ab9d7d7.3b1c4"
        "id": "a36d9476.1c27b8",
        "type": "ui_audio",
        "name": "Alarm",
        "group": "d05bc92c.1c937",
        "voice": "en-US",
        "always": false,
        "x": 830,
        "y": 700,
        "id": "d05bc92c.1c937",
        "type": "ui_group",
        "z": "",
        "name": "Clock in Toolbar",
        "tab": "1c488775.b324b1",
        "order": 7,
        "disp": false,
        "width": "6",
        "collapse": false
        "id": "1c488775.b324b1",
        "type": "ui_tab",
        "z": "",
        "name": "Weather",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
I don't understand the issue, could you explain it a little more
the "audio out Node" (dashboard) sometime it speak on the dashboard and sometime it give "Error: not alowed"
I cannot determine what is causing this error or where it is coming from
thank you for your help
a lot of browsers these days block audio output by default unless the users does something... it may have to be enabled, it may just require a click, depends on the browser.
its MacOS 11.1 where I doing editing NodeRed is running on a Raspberry Pi4 and the dashboard is on a Android tablet... it very shadowy
