I am using the modbus read node (Modbus TCP/Serial read node.), and reading the Holding registers. I've tried to search for the problem in the data base but it resolves when i make an FULL DEPLOY, the read node starts to read the data. This is the Flow:
[{"id":"efe3dba9.c09438","type":"modbus-read","z":"a87b22c2.6a19c","name":"","topic":"","showStatusActivities":false,"showErrors":false,"unitid":"1","dataType":"HoldingRegister","adr":"19000","quantity":"20","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"f904cf0e.d70d4","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":1018.0833892822266,"y":157.16320037841797,"wires":[["e07c9eb5.db0d6"],[]]},{"id":"e07c9eb5.db0d6","type":"function","z":"a87b22c2.6a19c","name":"write_to_DB_ALARME_FUNCTIONARE","func":"var msg1 = {};\nif (msg.payload[0] === false){\n msg1.payload = 0;\n msg1.topic = "INSERT INTO db_kmr.sensors_values (reg_date, id_sensor,value) VALUES (NOW(),'326','"+msg1.payload+"')";\n return msg1;\n \n}\nif (msg.payload[0] === true){\n msg1.payload = 1;\n msg1.topic = "INSERT INTO db_kmr.sensors_values (reg_date, id_sensor,value) VALUES (NOW(),'326','"+msg1.payload+"')";\n return msg1;\n}","outputs":1,"noerr":0,"x":1320.017333984375,"y":155.0104217529297,"wires":[["fea65863.a97458"]]},{"id":"fea65863.a97458","type":"function","z":"a87b22c2.6a19c","name":"changes-only6","func":"var alarm = {};\nvar al = -1;\nvar nochange = {};\nif (global.get("alarm6") === undefined){\n alarm.payload = al;\n alarm.topic = '';\n global.set("alarm6",alarm);\n}\nif (msg.payload !== global.get("alarm6").payload){\n alarm.payload = msg.payload;\n alarm.topic = msg.topic;\n global.set("alarm6",alarm);\n return alarm;\n}\nif (msg.payload === global.get("alarm6").payload){\n nochange.payload = "no change, last value: " + msg.payload;\n return nochange;\n}","outputs":1,"noerr":0,"x":1596.017333984375,"y":155.0104217529297,"wires":[["ef20abe4.05a418"]]},{"id":"ef20abe4.05a418","type":"mysql","z":"a87b22c2.6a19c","mydb":"5396c75e.697288","name":"","x":1815.795166015625,"y":159.0104217529297,"wires":[[]]},{"id":"f904cf0e.d70d4","type":"modbus-client","z":"","name":"Janitza UMG604E","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"10.10.9.42","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"19200","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"100","clientTimeout":"1000","reconnectTimeout":"2000"},{"id":"5396c75e.697288","type":"MySQLdatabase","z":"","host":"127.0.0.1","port":"3306","db":"db_kmr","tz":""}]
