volvog
27 September 2024 10:38
1
Due to some issues in virtualization I had to re-setup my NodeRed VM. Now the basis is Ubuntu 24.04.1 (before 22.04.5) and Nodered is 4.0.3.
I copied the whole .node-red folder and restarted Nodered. Everything available again.
BUT: Now I often get messages like
"Read -> resetIntervalToRead node 8eb943eafa5f7625 address: 0X484"
"Read -> resetIntervalToRead node 5956e716afe1d287 address: 0x584"
"Read -> startIntervalReading node 8eb943eafa5f7625 address: 0X484"
"Read -> startIntervalReading node 5956e716afe1d287 address: 0x584"
I haven't had this before?!? What's the reason?
In the modbus server-configuration I deselected already all Logs and Warnings...
Any ideas?
You should not copy node_modules
in fact, you should stop node-red, delete .node-red/node_modules, run npm install inside .node-red
Some nodes have compiled parts and may need rebuilding.
Also, check/ensure all installed nodes are up-to-date.
Colin
27 September 2024 11:20
3
Also make sure all your installed nodes are using the latest versions. Check in Manage Palette.
volvog
27 September 2024 11:38
4
All nodes have been updated...
Colin
27 September 2024 13:21
5
Assuming that you have already followed Steve's advice then you might be best to ask on the node's github page .
I can see where the message is generated in the code but it is not clear what the significance is.
