Azure IOT hub node
Hi, I am trying to use Azure IOT hub node to send data from a DHT11 sensor to Azure, the problem is when I installed the nodes in node red through the manage palette I chose (node-red-azure-iot-hub-mod) which is giving me an azure iot node with 2 outputs as shown in the picture below. I want to get an Azure iot hub node with just one output cause the one with 2 outputs in not functioning as it suppose to be. Do I need to delete it and re install it again or what is the solution
Yes, remove the node from your flow, redeploy, remove the node using the pallet manager. Then add the other one.
Thank you, problem fixed. :grinning:
