Hi! I'm having a problem with connecting my hub to node red.
I was watching this tutorial and I have the same "Azure IoT Hub" node from "cloud", the difference is that when he edit the node in properties it says "connection string" and for me it says "Hostname", is there a way I can change that? ![]()
The top screenshot is set to use http the bottom one is set to use mqtt
I am going to use mqtt, but even if I change it to http it wont change to connection string... ![]()
