I need to install node-red on multiple devices with same nodes and flows. Is there any procedure where you could install and configure nodes in one device and then take a backup of node-red and use it to install and run the node-red on all other devices.
Hi @dhanishkarun welcome to the forum.
Please search the forum for offline install this has been covered many many times.
You should find many clues on how to do this.
Sure will try that. So far I couldn't find a discussion to for offline installation of node-red with all the nodes. Will read more and update it here.
thanks
