Bash script can't find the path
I'm brand new to nodered. When I saw the possibilities, I tried to install on my RPI4 by following the following tutorial: nodered.org > docs > getting-started > raspberrypi
When I get to the bash command, the RPI gives me the following error:
bash: /dev/fd/63: No such file or directory
A quick search on your forum indicates that the error has already been spotted but I did not know how to resolve it.
However, I can give you the following information about my installation.
1- I installed Git with the command "sudo apt install build-essential git"
2- Cat /etc/os-release :
PRETTY NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RasbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Thank you for your help and attention.
Welcome to the forum @Cracatus
Can you copy/paste the terminal output showing the command you are entering and the error please? Copy/paste rather than a screenshot please, if possible.
Also what do these commands show
node -v
which node
apt policy nodejs
Okay,
The commands give:
node -v
-bash: node: commande not found
which node
apt policy nodejs
nodejs:
   Installed: (none)
   Candidate: 10.24.0~dfsg-1~deb10u1
   Version table:
      10.24.0~dfsg-1~deb10u1 500
         500 http://respbian.raspberrypi.org/raspbian buster/main armf Packages
It therefore seems not installed by default correctly at the "node" level. But since I am starting from a very fresh isntalattion it is possible that something needs to be done.
Thank you
Before you run the script nodejs should not be installed, so that is ok.
Show us the output you are getting please. You haven't made it clear where that error is appearing.
and presumably the curl command is also installed ?
the error appears just after sending the bash command.
i can try a:
sudo apt-get install curl
I would like to be sure of the correct order.
Yes, do that, the script needs it already installed.
Then if it still doesn't work please copy/paste the command you are entering and the result. As I asked earlier.
It's pretty straightforward.
When I try to install curl I get this:
Reading package lists... Done
Building dependency tree
Reading state information... Done
curl is already the newest version (7.64.0-4+deb10u2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. ```
28 / 5000
Résultats de traduction
In order I do this:
pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get upgrade
pi@raspberrypi:~ $ sudo reboot
pi@raspberrypi:~ $ sudo apt-get install vim
pi@raspberrypi:~ $ sudo apt-get install build-essential git
pi@raspberrypi:~ $ sudo bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)
Am I wrong ?
Don’t use sudo When running the bash
And show us the command and the result, not just the command.
OMG, it works without the sudo ... Me using my commands. Good visibvlement must be done in order ... and transfer the sudo for the bash command
This is what is happening:
pi@raspberrypi:~ $ sudo apt-get install curl
pi@raspberrypi:~ $ bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)
Running Node-RED install for user pi at /home/pi on raspbian
This can take 20-30 minutes on the slower Pi versions - please wait.
  Stop Node-RED                       ✔
  Remove old version of Node-RED      ✔
  Remove old version of Node.js       ✔
  Install Node.js LTS                 ✔   Node v12.22.1   Npm 6.14.12
  Clean npm cache                     ✔
  Install Node-RED core               ✔   1.3.4
  Move global nodes to local          -
  Install extra Pi nodes              ✔
  Npm rebuild existing nodes          ✔
  Add shortcut commands               ✔
  Update systemd script               ✔
Any errors will be logged to   /var/log/nodered-install.log
All done.
  You can now start Node-RED with the command  node-red-start
  or using the icon under   Menu / Programming / Node-RED
  Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started  Wed 12 May 13:04:10 CEST 2021  -  Finished  Wed 12 May 13:06:30 CEST 2021
pi@raspberrypi:~ $
I test again to be sure of the procedure.
Well, I'm happy! It works perfectly. The error was with sudo, which should not be used with bash.
I have another question but it is far removed from this one. I therefore close the subject.
Thank you so much for your help.
Sincerely,
Alex
You only need to install the packages (build-esssential, curl etc) once, once you have installed them they are installed.
Why are you installing vim? Perhaps you need it for some other reason, but node-red does not need it.
