Hello everyone. Im new to Node Red and came across an issue when using the bigexec node to trigger a batch file. I found that even when the node is done running all of the commands in the batch file, it sort of hangs with a 'running for a few seconds' message visible under the node. Based on the way my flow is set up, I feed the bigexec different arguments each time the flow is triggered. the problem is that the bigexec node just hangs and wont do anything with subsequent triggers (until i re-deploy my flow again).
The bigexec node is one written by a community member (you can see by the contrib part of the name)
If you look at the node at https://flows.nodered.org/node/node-red-contrib-bigexec
you can follow a link to the github page where you can open an issue direct with the author
